CWM - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Comfort Webserver Module (OBSOLETE) (https://www.comfortforums.com/forum-49.html) +--- Thread: CWM (/thread-596.html) |
- salizam - 05-08-2007 mine is a firmware entry ver 5.054 comfort cp9000 control panel. other then the CWS itself, what do i need to install CWM on the system, and how much does it cost. ist available in msia, if not where can i buy it. really need it ASAP. Thanks - Guest - 05-08-2007 Entry does not support the CWM. You will require a firmware upgrade as well. Please approach your installer on its availability. |
