Comfort Bus Monitor 2 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Software Tools and Misc Interfaces (https://www.comfortforums.com/forum-27.html) +--- Thread: Comfort Bus Monitor 2 (/thread-6017.html) |
Comfort Bus Monitor 2 - slychiu - 11-10-2026 Comfort Bus Monitor 2 will replace the exiting Comfort Bus Monitor that is launched by Comfigurator > Tools menu. This shows the Comfort messages on the RS485 Bus Bus Monitor 2 improves on the old software;
The next Comfigurator (after 4.0.6) will launch Bus monitor 2, but for now the software can run stand alone. Download from https://www.cytech.biz/comfort_bus_monitor_2.html ![]() ![]() The log display example is below; Tuesday, 10 November 2026 No bus traffic after 3s - re-sent login + MO01 (UCM had sent "LU01" bytes=[03 4C 55 30 31 0D]) 16:35:38:468---03 41 45 30 31 37 36 02--- ►[41][45]0176◄ Keypad 01 key 01 is pressed 16:35:38:578---03 41 80 33 43 02--- ►[41][80]3C◄ Keypad 01 reports all keys released 16:35:39:012---03 41 45 30 32 37 35 02--- ►[41][45]0275◄ Keypad 01 key 02 is pressed 16:35:39:153---03 41 80 33 43 02--- ►[41][80]3C◄ Keypad 01 reports all keys released 16:35:39:465---03 41 45 30 33 37 34 02--- ►[41][45]0374◄ Keypad 01 key 03 is pressed 16:35:39:620---03 41 80 33 43 02--- ►[41][80]3C◄ Keypad 01 reports all keys released 16:35:40:712---03 41 45 30 34 37 33 02--- ►[41][45]0473◄ Keypad 01 key 04 is pressed 16:35:40:869---03 41 80 33 43 02--- ►[41][80]3C◄ Keypad 01 reports all keys released 16:35:41:444---03 41 45 30 43 36 42 02--- ►[41][45]0C6B◄ Keypad 01 key 0C is pressed 16:35:41:475---03 41 80 33 43 02--- ►[41][80]3C◄ Keypad 01 reports all keys released 16:35:41:490---03 41 61 30 31 30 30 35 41 02--- ►[41][61]01005A◄ Code validation reply command 16:35:41:521---03 00 42 30 30 30 30 42 42 02--- ►[00][42]0000BB◄ Request Broadcast to turn off mic, turn off speaker 16:35:41:569---03 41 42 30 30 30 31 37 39 02--- ►[41][42]000179◄ Request Keypad 01 to turn off mic, turn on speaker 16:35:41:614---03 41 4F 30 31 36 43 02--- ►[41][4F]016C◄ Request Keypad 01 backlight on 16:35:43:560---03 12 60 30 31 30 32 30 33 30 34 38 31 02--- ►[12][60]0102030481◄ Code validation submission command 16:35:43:592---03 12 61 30 31 30 30 38 39 02--- ►[12][61]010089◄ Code validation reply command 16:35:43:733---03 12 6E 37 44 02--- ►[12][6E]7D◄ Request/Report current alarm type 16:35:43:792---03 00 46 42 37 02--- ►[00][46]B7◄ Turns off siren 16:35:43:824---03 00 3D 31 38 30 31 30 31 46 38 30 33 34 32 36 39 02--- ►[00][3D]180101F8034269◄ Alarm report for Broadcast: alarm type 18H, priority state trouble (01H), new state trouble (01H), sentence 248, param type ID (03H), param ID 42H 16:35:43:886---03 00 6E 31 38 30 31 30 38 30 30 30 30 30 30 34 32 30 30 30 30 32 43 02--- ►[00][6E]1801080000004200002C◄ Alarm type 18H, state trouble (01H), trouble: RS485 comms fail, low battery ID 00H, zone trouble 00H, comms fail ID 42H, tamper ID 00H, GSM ID 00H 16:35:43:948---03 40 41 30 30 30 32 30 30 30 30 37 41 02--- ►[40][41]000200007A◄ Request All Keypad turn off ARM LED, flash OFF LED, turn off AC LED, turn off MSG LED 16:35:44:011---03 12 6E 31 38 30 31 30 38 30 30 30 30 30 30 34 32 30 30 30 30 31 41 02--- ►[12][6E]1801080000004200001A◄ Alarm type 18H, state trouble (01H), trouble: RS485 comms fail, low battery ID 00H, zone trouble 00H, comms fail ID 42H, tamper ID 00H, GSM ID 00H 16:35:54:045---03 12 73 30 30 37 38 02--- ►[12][73]0078◄ Zone bypass query/reply 16:35:54:076---03 12 73 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 37 38 02--- ►[12][73]0000000000000000000000000078◄ Zone bypass query/reply 16:35:54:116---03 12 67 38 34 02--- ►[12][67]84◄ Ucm 02 requests version information 16:35:54:153---03 12 67 46 39 30 38 34 33 32 32 34 30 30 31 30 30 44 44 02--- ►[12][67]F9084322400100DD◄ Version information sent 16:35:54:161---03 12 97 30 31 35 33 02--- ►[12][97]0153◄ Ucm 02 request comfort about 01's information 16:35:54:177---03 12 97 30 31 34 30 30 38 33 38 30 30 30 31 44 32 02--- ►[12][97]014008380001D2◄ Unhandled command 97H frame (length 11) 16:35:54:200---03 12 B6 30 35 30 31 30 31 32 45 02--- ►[12][B6]0501012E◄ DC/battery voltage query/reply 16:35:54:215---03 12 B6 30 38 30 31 30 31 44 36 35 35 02--- ►[12][B6]080101D655◄ DC/battery voltage query/reply 16:35:54:226---03 12 B6 30 35 30 31 30 32 32 44 02--- ►[12][B6]0501022D◄ DC/battery voltage query/reply 16:35:54:263---03 12 B6 30 38 30 31 30 32 44 46 34 42 02--- ►[12][B6]080102DF4B◄ DC/battery voltage query/reply 16:35:54:278---03 12 A3 30 31 34 37 02--- ►[12][A3]0147◄ Ucm 02 Query CM EOL Setting 16:35:54:309---03 12 A3 30 34 31 30 46 46 46 46 46 46 46 46 46 46 33 39 02--- ►[12][A3]0410FFFFFFFFFF39◄ Ucm 02 CM Reply with EOL of itself 16:35:54:347---03 12 35 37 46 46 39 30 34 33 41 02--- ►[12][35]7FF9043A◄ Upload to Ucm 02 16:35:54:373---03 12 36 37 46 46 39 46 46 46 46 46 46 46 46 34 31 02--- ►[12][36]7FF9FFFFFFFF41◄ |
