Alarm Turn All Lights On - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: CBus (https://www.comfortforums.com/forum-11.html) +--- Thread: Alarm Turn All Lights On (/thread-920.html) |
- songkot - 01-15-2008 When system is alarming some lights don\'t Turn on.But all lights can turn on with Home Control function.(same responce) Do LIGHT1 [Light 1 On] Do LIGHT2 [Light 2 On] After 3 Seconds Using Timer02 Do LIGHT3 [Light 3 On] After 3 Seconds Using Timer03 - hendy - 01-15-2008 Is this a new install or the system has been up and running for quite some time before this problem occured? - palmlodge - 01-15-2008 You could load WizComfort and watch the live traffic - does it even attempt to send the cbus commands ? Ive had to use timers as if you send too many cbus commands at once, it all falls apart. The CBUS UCM could do with an internal queueing system - hard to trust what it does. - admin - 01-15-2008 Check that the timers are not used elsewhere by other responses, which may have stopped the timers As palmlodge says monitor the communications using WizComfort or Comfigurator Monitor I/O CBus activity is reported as CT commands (Counter) Too many Cbus commands in the same Response may cause some to be lost. The CBus SIM Modules manufactured by Clipsal themselves have a limitation on the number of Cbus commands they can take at one time If you still have problems, send the CCL file to support@cytech.biz - songkot - 01-21-2008 Thank for your advise.I will go on site next week. |
