DM01 and Doorbell response - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: DM01 and Doorbell response (/thread-993.html) |
- Warby - 03-26-2008 I am trying to get a Output to pulse when the Doorbell is pressed (DM01 and Fermax unit) i have tied the response to Misc. Events-Doorbell response. is this correct as it doesnt seem to be working!! Thanks - admin - 03-26-2008 Thats correct It should work See the comms in Monitor I/O and watch for the DB and OP messages Also test with a test lamp on the output - Warby - 03-26-2008 Ihave tried it using the monitor and it is say\'s Rx: <STX>OP1301<CR> Rx: <STX>OP1300<CR> The response is Output Output019 On Do DoorBell_Off [Set Doorbell_Camera output Off] After 10 Seconds Using DoorBellCamera And doorbell_Off is: Output Output019 Off It is the third output on the 1st slave board (all jumpers In for address) Firmware is 5.121 - Warby - 03-26-2008 Of course the Monitor is in Hex hence 13. will have to keep trying! - admin - 03-26-2008 You can see that Comfort is pulsing the outputs or at least trying to The possibilities are that what is connected to the outputs is not turning on, or the outputs may be damaged in some way The Monitor I/O is a useful tool in these situations - Warby - 03-26-2008 It is very helpful. is there any documention on what the codes are. some are obvious but others not so? - admin - 03-27-2008 The codes are documented in the Serial protocol document in the website www.cytech.biz/techinfo.html Scrolll down and look forr \"Serial Command Set\" - admin - 03-27-2008 [user=1229]Warby[/user] wrote: Quote:Ihave tried it using the monitor and it is say\'sYou have used a Timer to turn off the Output. This is OK but a batter way is to use the Pulse Output command Pulse Output019 For 20 This pulses the Output for 1 second (units of 50 ms) It saves you a timer! |
