Comfort Home Automation/ Security System Forums > Support > FAQs - Technical > Firmware Upgrade in Comfort II Firmware before 5.100
 Posted: Sunday Nov 12th, 2006 03:15 pm
For Comfort I, firmware upgrades were by replacement of the U1 IC, which was an (84 pin PLCC) IC in a socket.
For Comfort II, the processor or microcontroller is soldered into the PCB. To upgrade the firmware, a Plug in Module MPU-ULT or MPU_OPT depending on the model is needed. Make sure that the correct firmwaqre upgrade is used  corresponding to the Comfort Moldel, Ultra or Optimum
See the photo above which shows the front and back of this module.
Ensure that the power is off and the Battery disconnected before attempting this, otherwise Comfort and/or the MPU board may be damaged.
The back of the module has 4 rows of headers which plugs in on top of the Comfort Main board to J8, J9, J10, J11 around the U1 IC. Position the 4 rows of headers on the MPU01 directly over the corresponding sockets J8 to J11. The triangle mark on the edge seen on the MPU01 should be aligned with the trangular mark on the Comfort board below. Gently push the MPU01 down until it comes to a firm stop. Examine the connection to ensure that the headers and sockets are properly aligned without any pins sticking out.
Remove two position Shunt J14 in order to enable operation of the MPU01. J14 must be shunted when the onboard U1 is in control and removed when the MPU01 is in control
After checking that everything is in order, turn on the power and connect the battery. Comfort should start up and announce "Security Off" as usual. Remember to set Date and Time.
The programmed settings for the system do not need to be reprogrammed as they are saved in U4 Nonvolatile memory
If the shunt J14 is in the wrong position, the system may not work, or the RESET button may not work
Attachment: MPU front back small.jpg (Downloaded 209 times)
 Posted: Saturday Dec 30th, 2006 08:12 pm
marinoss
Could you please let us know if the Plug in Module MPU-ULT is available for purchase?
 Posted: Sunday Dec 31st, 2006 02:20 am
It certainly is available for purchase
 Posted: Thursday Aug 14th, 2008 02:36 pm
freeco
my system didn't work untill i reset it , after the disarming from any mode (night mode / day mode / away mode ) the system need to be reset again , when i press any mode button voice message is played talled me " invalid call engineer to reset "
what is the problem ?
i need fast answer please .
note ( when trying to shunt j14 give me message on kp screen " communication failuer "
and kp didn't work .
 Posted: Thursday Aug 14th, 2008 02:53 pm
Please see reply in the Troubleshooting Forum
http://www.comfortforums.com/forum36/1143.html
which is the correct place to post this question
 Current time is 08:47 am
