Comfigurator 3.2.0 is now ready for beta testing.This new version has many new features and productivity enhancements as well as bug fixes and reduces Exceptions.
Bugs Fixed
Bugs Fixed
- For Phone Numbers to Dial Out, CMS Phone Types are now not allowed for valid for Phones 3 to 8
- Zwave Configurator Counter assignments were not displayed correctly
- IR Learner Utility in Windows 7 is now able to save the learned IFR file, see topic at http://www.comfortforums.com/view_topic.php?id=1827&forum_id=20
- Response Wizard for Cbus Action; if Remote Network Bridges are specified, these can now be deleted from the action, exceot by deleting the action
- Invalid IFR files in the existing IFR folder caused Comfigurator to have an Exception when the program is run.
- Modules ID in Modules Tab can be swapped with other IDs. eg if UCM ID 1 is changed to 3, then the UCM at ID=3 is changed to 1 with a warning message. Note that this refers to the configuration settings, whereas the physical IDsmust be changed to match
- Added new C-Bus Action in Response Wizard: Stop Dimming
- Added new C-Bus Action in Response Wizard - Label (requires new Comfort firmware 5.190 not released)
- Fixed Bug for Learning Velbus modules - when the number of modules is > 40, Read EEPROM error occurs
- VMB4PD module supports 2 pages of 4 buttons instead of 1 page
- VMB1BL and VMB2BL Switch Blind Off Command in Response wizard is supported
- Bug if Velbus module name has 16 characters. Keep the name to less than 16 characters
- Velbus Learn operation will not erase previous assigned counters and sensors
- Zwave Configurator does not work
- Scan Keypads does not show firmware version for KT03
- IR Receive Responses - if assigned to NULL, will call Response 255 if the IR signal is received. To workaround, do not use Response Number 255
- When Say Word Action is the last action in the Response, Comfigurator does not append another 255 to end the Response. hence if there are exactly 8 codes in the action including the 255 to terminate the Say words action, the Response will not terminate but continue into the next Response.. This is an existing bug even for older versions of Comfigurator. To work aorund, add a dummy action after the Say Word action.
- When Send RS232 Action is the last action in the Response, Comfigurator does not append another 255 to end the Response. hence if there are exactly 8 codes in the action including the 255 to terminate the action, the Response will not terminate but continue into the next Response.. This is an existing bug even for older versions of Comfigurator. To work aorund, add a dummy action after the Send RS232 action. Applies to CBUS and KNX actions
- When the name of an Alarm Type is changed, the Zone Types which trigger that alarm type still shows the old name until the Alarm Type for that Zone type is selected again.
- IR Transmit codes which have codes numbered near the end of the table ie 250 but which have gaps inn the IR numbers may overflow into the Alarm Types Table causing the Alarm Types to have the wrong information. Please use consecutive IR code numbers without any gaps
- Selective write may not be complete - the last line is not written to Comfort. Please use Full Write instead as a workaround. see http://www.comfortforums.com/view_topic.php?id=2197&forum_id=20 for full details
- The Alphanumeric Text ID feature does not work on Comfort Optimum UCM/GSM because of an error in the IOMAP.CYM file. Contact Cytech for the correct file
- For KT03 and Velbus Configurators, if a Response is referenced and the Response name is changed in the Responses page, the name change is not updated in the respective KT03 and Velbus pages.
- Reading a ccl file with Siren Duration < 1 second causes the siren Duration to be 0 resulting in an indefinate siren duration
- Reading a ccl file with less than 8 UCM will cause 8 UCMs to appear in the Modules Tab. The Numver of UCMs in Modules and Settings will not be 8. However when you change the name of a UCM or delete a UCM in the Modules tab then the number of UCMs in Modules and Settings will change to the wrong number.
