Search by username
Comfigurator text
 New Topic   Reply   Print
Status:  Offline
 Posted: Monday Sep 25th, 2006 07:53 am
 Quote  Reply
An old problem of ours
Since i last reported this we have had several occurances of the text dropping out of the general comments box.
I cannot repaet it but it is a regular occurance and rather annoying
Status:  Offline
 Posted: Monday Sep 25th, 2006 01:42 pm
 Quote  Reply
Do you remember what you were doing when this happened, were you entering text at that time, or doing other things? Was the text completely lost? or was there some text?
Could it be that it was not saved since adding text?
Status:  Offline
 Posted: Monday Sep 25th, 2006 03:02 pm
 Quote  Reply
The text is never lost while in comfigurator - it is only ever lost when re-opening an old file
It is NOT due to saving as the entire text string is invariably lost i.e. other previous saves as well
I recall a couple of occasions where some text has remained (only a line or 2) of the most recent comments but all other text has vanished.
There is a possibility that we ae filling up the text string and then the tet just drops off the end - but I recall that someone looked at this possibility before
adlim
Status:  Offline
 Posted: Monday Oct 2nd, 2006 02:36 am
 Quote  Reply
Do you have any exclamation (!) in the general comments box?
Comfigurator treats the exclamation as the start of a comment. As such the text following that will be dropped.
For instance, when you key in the following in the comments box:
"1234567890!ABCDEFGHI"
Upon reopening  the ccl file, it appears as:
"1234567890
That might explain the problem of lost text.
Status:  Offline
 Posted: Thursday Nov 23rd, 2006 02:20 pm
 Quote  Reply
I dont remember putting an ! but its possible.
Are there any other caracters to look out for - is this something that can be eliminated within the comments box
I have had the same thing happen again yesterday - I can forward the files!
Status:  Offline
 Posted: Thursday Nov 23rd, 2006 02:30 pm
 Quote  Reply
Comfigurator 2.1.2 (beta) is available, see http://www.comfortforums.com/forum20/369.html
This fixes the problem where the ! character causes comments to disappear
 Current time is 02:53 pm
