These are the changes in the next version of Comfigurator 3.4.x being tested before release
Bugs Fixed
- KT03 Configurator - Fixed problem of Buttons jumping to another location when pressed, and button properties on the right pane become blank due to memory leakages.
- No of Slaves allowed was 4 instead 5
- RIO status in Names > Outputs was shown as Unknown when Show Status button is checked
- Invalid Value for PABX Digit in a CCL file caused an exception when the file is opened in Comfigurator 3.
New Features- New Splash screen when Comfigurator Loads
- Support for new 2 way Z-Wave UCM
- Support for new e-Home UCM
- Event log supports Engineer User number = 254, Keypad user change from 90 to 240, Response from 91 to 241, SMS from 95 to 245
Known Issues- KT03 Configurator - if sensor status is used in Buttons and sensor name is changed, the sensor name remains unchanged in the KT03 page
- Scanning for Modules may fail for unknown reason intermittently. When the scan fails while attempting to do Firmeware Upgrade by Bus, Comfigurator is logged out but the Firmware upgrade starts without logging in again so it fails without getting started.
- Bus Monitor (in Tools) display is limited to 128 characters, and will result in the initial characters not displayed if the message line is longer than 128
- Number of Outputs for a 96 zone system remains at 64
- UCM/Cbus may lose commands to group addresses if UCM ID 1 is NOT present in the Comfigurator and file is saved. This may happen if anither UCM or a KT03 is used to program Comfort. Workaround is to manually ADD UCM at ID=1
- Zwave Comfigurator - Zwave Mapping unable to select Counter 000
These known issues are not necessary new with this version and may have been present in older versions
