Comfigurator 3.6.5
 Posted: Wednesday Feb 20th, 2013 05:45 am
Comfigurator 3.6.5  can be downloaded from http://www.cytech.biz/product_details.php?item_id=206
This fixes bugs in 3.6.4
Bugs fixed
  1. In KT03  adding a clock element caused an exception
  2. Write to KT03 may not work in some situations This was a  bug fixed in 3.6.4  but it may still occur but less often. "RS4x" reply is seen in I/O Monitor. it is suspected that a hidden exception caused it, now the exception wil be visible.
  3. In KT03 selecting all buttons on a page and Copying may cause exceptions
  4. Read from Comfort with the option "Auto-generate Names"  caused an exception.
  5. When the cursor is in the Modules Tab and the UCM connections in Options > settings is changed, the screen jumped back to the Comfort Tab although the Modules Tab is still selected
  6. Bus Monitor had exception in some circumstances and wrong messages about illegal commands are shown
  7. Minimising Comfigurator during a firmware upgrade is now prevented so the Comfigurator screen is not locked out like before
  8. If firmware upgrade stops due to no reply from Comfort, a dialog contiinue from last address appears, but if UCM/ETH02 is used, and connection is lost, Comfigurator does not try to reconnect before continuing the upgrade
  9. Zwave Status messages have been expanded.
Known Issues
  1. For Zwave Connfigurator, the last line of Zwave Mapping is not written to EEPROM with the other lines, ie the assigned Comments and Comfort Register is not written to EEPROM. The workaround is to Read from EEPROM before adding the last line mapping and comments before writing to EEPROM
  2. For Zwave configurator, if a zwave node (virtual Node) is mapped to Virtual Input and the virtual node is removed, without first unmapping the Virtual Input, this causes the Comfort Zone/Input to remain as Virtual Node and this cannot be changed. Workaround is to unmap the virtual Input before deleting the Zwave virtual Node
  3. In Bus Monitor, if the Exit Button is pressed without first pressing the Halt button, the UCM will remain in Bus Monitor mode even though the Bus Monitor software has ended, and the UCM will not work normally, until the UCM is reset
  4. in KT03, copying the keypad Buttons Away, Night, Day arm buttons and pasting will leave the button actions empty, ie the button actions are not copied
 Posted: Thursday Feb 21st, 2013 11:19 am
The new Programming with Comfigurator Manual can be downloaded from http://www.cytech.biz/product_details.php?item_id=154
This covers the changes in Comfigurator 3.6.x
 Posted: Friday Feb 22nd, 2013 08:25 am
Comfigurator 3.6.5 is released
Please upgrade to it as soon as possible as it fixes some issues in Comfigurator 3.6.4 see above list
Users of Comfigurator 3.6.x can upgrade automatically if the PC is connected to the Internet  using the Menu Help > Check for Updates. Also Comfigurator 3.6.x will prompt to update the software when it is run
 Posted: Saturday Feb 23rd, 2013 08:28 am
In 3.6.5 I've noticed that if you check for firmware updates from the Modules tab then the "Latest Version" does not show in the attributes until you Tab away from the page and go back again.
 Posted: Sunday Feb 24th, 2013 01:07 am
I dont see this
If I right click on a UCM and do check for updates, it says eg "current version is the latest" and shows the version and latest version
The best way to see all the latest versions is to do Scan for all modules
Then the latest version is seen for all
 Posted: Friday Mar 1st, 2013 06:37 am
2 problems wth Zwave Configurator for Comfigurator 3.6.5 have been found
 Posted: Saturday Mar 2nd, 2013 08:39 am
Is there a version to revert to that doesnt have these issues?
 Posted: Saturday Mar 2nd, 2013 08:59 am
No, unless you go back to 3.5.6 but that lacks may of the new Zwave features
There should not be any problems wth 3.6.5 as long as you are aware of the problem and the workarounds
 Posted: Monday Mar 4th, 2013 07:36 am
Bug found in Bus Monitor for Comfigurator 3.6.5
Please HALT Bus monitor before pressing EXIT from Bus Monitor
 Current time is 04:38 am
