Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Comfigurator 3.7.7 / 3.78
#1
Comfigurator 3.7.7 can be downloaded from https://www.cytech.biz/comfigurator.html
This fixes the  bugs found in 3.7.6 and added some useful features
A number of users reported exceptions in 3.7.6 some of which could not be duplicated. We would like feedback from them whether the exceptions still occur
Known Issues
  1. Read User Codes does not work
  2. Thermostat function registers are displayed by name but not in alphabetic order
  3. Heatmiser display date format in Heatmiser module properties are missing the / separator eg 21/1113 instead of 21/11/13
  4. Execute Responses when the Response is longer than 24 bytes will ask to write to Comfort but after writing, Execute Response will still ask to write to Comfort
  5. Display of Serial Numbers for Comfort is incorrect, shows Invalid. Serial Numbers are correct  for UCMs
  6. When reading event log and Comfigurator is on the GSM4 or Zwave or Heatimiser configuration tab, the event log may get an error message \"Event Log Format Invalid.. RA..\" The workaround is to move  the cursor away from GSM4, Zwave or Heatmiser UCMs before reading event log
  7. Module Scan may be interrupted by some status reports and give error message \"Module Scan Timed out - Please retry later\". If this occurs, just redo the Module scan
Bugs Fixed
  1. Action \"Add Immediate\"  causee Sensor 0 and Counter 0 to show as Referenced in blue. This also occurred  in older versions
  2. Write to KT03 by UCM/ETH02 (not direct to KT03 USB) if a network error closes the connection, does not give the option \"Continue from Last Address\" so requiring Write to KT03 again. This also occurred  in older versions
  3. When doing module scan by Remote Ethernet connection there may be a wrong message \" Comfort firmware 7.xxx does not support Module Scan. Please add modules manually\".
  4. In UCM/Zwave where Switch Multilevel Nodes are mapped to Responses, if the Response number changes in Comfort, the mapped Response number does not change.
  5. When firmware is upgraded to 7.040, some Serial Numbers may be wrongly generated and cause exception
  6. In KT03 Simulation Mode, Flag state was not shown correctly (but is OK on actual KT03)
  7. When a new template is opened, and Scan for Modules is done in a system with a programmed KT03, after the KT03 is scanned, clicking in some of the KT03 pages will cause an Exception.
  8. when upgrading firmware for UCM/KNX, message says \"Upgrading firmware to UCM/EIB\"
  9. UCM/Zwave compatibility problem for Response created by older Comfigurator 3.6. Empty channel becomes converted to Channel 1 because a blank channel cannot be selected
New Features
  1. Zwave Poll time 0 help text changed to \"The  Time Interval (in 10 second units) to poll mapped Zwave nodes for status . 255 means no polling. 0 means Smart Polling from Zwave 7.031\"
  2. The Yellow Boxes in Comfigurator right pane used for Response Errors will appear only if there is content. This used to obscure more useful information which required the boxes to be resized
  3. After completing a Scan for Modules, if there is at least 1 \"Not Polled\" result,  a message will pop uo \"One or more modules are not polled. Write Modules to Comfort?\". This is useful as people often forget to write modules and settings after adding a module and scanning for it
  4. In Responses, \"Duplicate Responses\" is now available on Right Click. This duplicates the selected Response, which is useful when many similar responses are needed, differring by soemthing eg counter number
  5. Portugal Defaults changed to the correct Portuguese wordlist
  6. Sunrise/Sunset Times added many Portuguese cities and corrected Time zone
Reply
#2
Sadly I got an exception first time I loaded, as per below.
If I open a pre-heatmiser config it works, and then also loads my latest config (with heatmiser).
System.NullReferenceException: Object reference not set to an instance of an object.
at Comfort.UcmHeatmiserMapping.get_RegisterName()
at Comfort.UcmHeatmiserMapping.AddReferences(Dictionary`2 references, UcmHeatmiser ucmHeatmiser)
at Comfort.Configuration.BuildReferences()
at Comfort.Configuration.GetReferences(ConfigListItem configListItem)
at Comfort.Response.FlagOmittedResponses(Configuration configuration)
at Comfort.Response.EncodeResponses(Configuration configuration, Boolean flagRequireWriteToEeprom)
at Comfort.Form1.SetNewConfiguration(Configuration newConfiguration, Boolean keepPanel)
at Comfort.Form1.NewConfiguration(String filename)
at Comfort.Form1..ctor(String filename)
at Comfort.Program.Main(String[] arguments)
Reply
#3
Did you get this exception with 3.7.6?
Can you send the cclx file to support@cytech.biz please
Reply
#4
Thanks ident - I\'ve emailed the CCLX file. Yes I twas getting it with the 3.7.6 version of Comfigurator too, but only since using heatmiser ucm...
Reply
#5
Comfigurator 3.7.8 (Beta) can be downloaded from the website
The changes are
Known Issues
  1. when connected to KT03 USB, Comfigurator repeatedly sends f?00 message
Bug Fixes
  1. Thermostat function registers were displayed by name but not in alphabetic order
  2. Heatmiser display date format in Heatmiser module properties were missing the / separator eg 21/1113 instead of 21/11/13
  3. Execute Responses when the Response is longer than 24 bytes  asked to write to Comfort but after writing, Execute Response will still ask to write to Comfort
  4. Display of Serial Numbers for Comfort was incorrect, shows Invalid.
  5. When reading event log and Comfigurator is on the GSM4 or Zwave or Heatimiser configuration tab, the event log may get an error message \"Event Log Format Invalid.. RA..\"
  6. Module Scan may be interrupted by some status reports and give error message \"Module Scan Timed out - Please retry later\". If this occurs, just redo the Module scan
New Features
  1. Comfort Server Manager link for UCM/ETH03 is seen next to DS Manager (for UCM/ETH02)
  2. Heatmiser configurator has been improved, Read Only parameters are shown, and more parameters are supported. This requires a new version of UCM/Heatmiser 7.034
  3. UCM/GSM4 Zone Names, Alarm Names, User Names allows spaces in the names
Reply
#6
Thanks - I\'ve updated to 3.7.8 but am still getting the exception as above when I launch with the CCLX with my heatmiser config in...
Any view when Heatmiser 7.034 will be out and what additional parameters will be supported? Will the new parameters require a relearn and thus a remapping of all existing registers?
Cheers, Simon
Reply
#7
We have not managed to duplicate the exception even with your cclx file
That suggests it may be a problem with one of the installed files
Try  relearning the Heatmiser. This will not erase the mappings that you have assigned
Also uninstall and reinstall your Comfigurator
You can see the changes in Heatmiser mapping in Comfigurator
The new firmware should be available for testing soon
Reply
#8
Comfigurator 3.7.8 is released
It fixes all bugs that have been identified so far
Please upgrade
Reply
#9
I\'ve just upgraded to 3.7.8. Issues I\'m seeing are:
- Still getting phantom KP04 keypad if I scan for all modules
- Cannot update firmware on KT03 via network. If I right click over the module, I do not see \"Check for firmware updates\" and under Transfer/Firmware Upgrade I only see \"By Firmware programming Cable...\" no option for using UCM via network.
I have configured Comfigurator to use Network (local).
S
Reply
#10
-  How many keypads are connected to your system? Is the first keypad KP04 model?
- I\'m always seeing the \'Check for Firmware Updates\' every time I right-click on any keypad in 3.7.8. What are the options you seeing? A screenshot will help.
Reply
Forum Jump:
Users browsing this thread:
1 Guest(s)
