Search by username
Comfigurator 2.2.2
 New Topic   Reply   Print
Status:  Offline
 Posted: Wednesday Sep 19th, 2007 06:49 am
 Quote  Reply
Comfigurator 2.2.2 is a maintenance release to fix known bugs in 2.2.1 can be downloaded from http://www.cytech-technology.com/temp/software/Comfigurator2.2.2_Single.zip
Released 18 Sept 2007
Bug fixes
  • Validate name in new zone, zonetype and alarmtype dialogs
  • Fix problem uploading/downloading sensor feedback in control menu
  • Show referenced sensor responses
  • Fix problem with Dynalite commands shown as SendRS232
  • Update references when alarmtype or zone name is changed
  • Fix incorrect Ulti action descriptions
  • Fix crash when executing very long response
  • Fix problem with progress > 100% in event log upload
New Features
  • Login not required for Firmware Download
  • Login Window for Download has warning "Press F0 and enter Engineer code on keypad"
Known Issues
  • Alarm Types Names not uploaded correctly (Comfort > PC)
  • Misc Events > User Responses are not shown as Referenced responses
  • Reminders are not shown as References
  • No Sunrise/Sunset available for Vietnam
  • X10 Responses and housecode for FS31 and FS18 revert to default after saving the ccl file
  • Reminders 9 to 16 on/off settings download wrongly
  • Open Door Action allows UCM ID, not Door Station ID
  • Editing Tuning Parameters incorrect limits applied
Please note that Engineer Code is required for download and upload. First, press F0 to enable Engineer code before entering Engineer Code
The default Engineer Code is 6789.
In order to enable engineer Code without pressing F0,  do the following
1 Start Comfigurator
2  Select [Transfer] [Monitor I/O]   so that it is ticked.
3 Select [Transfer] [System Information]
4.  If asked for a password enter a normal user code,   not the engineer code.
The system info window pops up,  if it does not then your cannot do anything until that issue is resolved.
5 Click [OK]  on the system info window to get rid of it.
6 Now in the long one line  ( command line field of Comfigurator) type  DA5C01  followed by carriage return. (This means Do Action - Enable Engineer)
You should see the following in the log window.
Tx: <STX>DA5C01<CR>
Rx: <STX>PS01<CR>
Rx: <STX>RA00<CR>
The PS01  is the system reporting that engineer code is now enabled.
7  Now do a standard [Transfer] [Download PC> Comfort],  and all should be well with the world.
Ian Clarke
Status:  Offline
 Posted: Monday Oct 1st, 2007 01:27 am
 Quote  Reply
Hi Chiu,
please clarify, before doing a download, do you have to just press F0,  or do you have to press F0 and sign in as the engineer on the keypad.  This is what your instructions say.  I understood that we only have to press F0 on the keypad.
I think it worth also telling engineers how to do this remotely from Comfigurator by typing DA5C01  in the command line window of the monitor I/O windowl.
Regards  Ian
Status:  Offline
 Posted: Monday Oct 1st, 2007 01:56 am
 Quote  Reply
The instruction on the download screen reads "Press F0 on the keypad and enter Engineer Code"
Since Comfigurator 2.2.0 introduced this new requirement, some users have complained about the inconvenience of having to press F0 and entering the Engineer code.
Having to enter the Engineer Code was requested by installers, to protect against unauthorised modification of the program by their customers which may lead to attendance by the installer to problems caused by the changes. The Installer thus will have the option whether or not too reveal the Engineer Code to the particular customer
F0 is required because Comfort always requires authorisation for the Engineer code. This is a protection for the user. It is not something that is required in some circumstances and not in others.
It is not necessary to have the PC next to the keypad to do a download. You just have to press F0 on the keypad once to allow engineer Code on the PC, until the next reset I dont think that is a great inconvenience.
You can also enter F0 on  Comfigurator using the Monitor commnunications window without even going to the keypad.  The steps are (kindly provided by Ian Clarke)
Tx: <STX>DA5C01<CR>
Rx: <STX>PS01<CR>
Rx: <STX>RA00<CR>
Alternately, instead of DA5C01, the string equivalent to F0 can be entered
KD0A
KD00
The first string is F key. The 2nd string is the 0 key
 Current time is 01:46 pm
