Search by username
Comfigurator 2.2.3
 New Topic   Reply   Print
Status:  Offline
 Posted: Monday Nov 26th, 2007 12:12 pm
 Quote  Reply
The new version of Comfigurator can be downloaded from http://www.cytech-technology.com/temp/software/Comfigurator2.2.3_Single.zip
This is a minor version release but it incorporates some useful features which were requested by users; eg comments in Actions, System Information from Comfort saved in the ccl file.
Sunrise/Sunset Responses have also bee added
V2.2.3 19/11/2007
Bug fixes
  • Fix incorrect upload of alarm type name
  • Show Miscellaneous Events -> User Responses as references
  • Show Reminders as references
  • Fix problem with X10 received responses reverting to housecode A for FS18 and FS31
  • Handle Open Door action id as doorstation id, not UCM
  • Reminder message on All Doorstations should use id 48, not 32
  • Increase timeout for sentence download operations
  • Fix bug in editing tuning parameters
  • Fix Reminders 9 to 16 On/Off settings download wringly
  • Fix Reminders 9 to 16 On/Off settings downloaded wrongly
New Features
  • Add comment to response action (editable in Select Action dialog)
  • Save Comfort version information in CCL file (viewable in General Information screen)
  • Monitor window can now be resized and minimised
  • Add sunrise/sunset times for Vietnam
  • Emphasise warning when attempting to download incompatible filesystem
  • Number nondetector alarms
  • Add Miscellaneous Events: Sunrise Response, Sunset Response, Door Station Voice On Response, Door Station Voice Off Response
  • Sort word list alphabetically in printed worksheet
Known Bugs
  • Timer 64 causes Unknown Exception Error
From Comfigurator 2.2.0 onwards, Engineer Code (default 6789) is required for download. User Code is not allowed for download
In order to auhorise the use of Engineer code, you need to press F0 on the keypad in order to authorise Engineer Code.
This is a protection from unauthorised access by Installers or other people.
gsnottingham
Status:  Offline
 Posted: Monday Nov 26th, 2007 04:01 pm
 Quote  Reply
Many thanks for this. The improvement to the monitor window is wonderful.
I can't seem to get system information into the general information page. Not sure why - it comes up when I call up system info from the transfer menu, but does not populate the general information page.
Please can you explain a little more about how to add comments to response actions (I can't find 'Select Action'). Also how do the user responses work - in other words in what circumstance are they executed? Finally, when do the new door station voice on responses happen?
Thanks for your continued help which is much appreciated
GS
Status:  Offline
 Posted: Tuesday Nov 27th, 2007 12:19 am
 Quote  Reply
The System Info goes into the General Information screen when you download or upload. It does not do so with the Transfer System Information upload alone
The purpose of this is to record in the ccl file all the system infomation whichcan help in troubleshooting and ither purposes
The Action comments window will open when you enter actions in the Response Wizard
The Monitor Window changes to allow it to be minimised and resized will help to allow it to be kept open while doing other editing in Comfigurator. Sometimes closing the screen may freeze Comfigurator, so the ability to get Monitor Window out of the way helps
gsnottingham
Status:  Offline
 Posted: Tuesday Nov 27th, 2007 06:12 am
 Quote  Reply
Thanks that's really helpful.
Can you also please explain when the 'door station voice on' and the 'user' responses are executed? The door station response is obviously new, but I have not had any success in programing the user responses previously.
GS
Status:  Offline
 Posted: Tuesday Nov 27th, 2007 11:28 am
 Quote  Reply
The User Responses are meant for the Comfort fingerprint reader, see http://www.comfortforums.com/forum43/235.html
Each user recognised by the FPR can activate the corresponding User Response, to arm or disarm the system, to unlock the door, turn on lights etc
The User Responses are not activated by the keypad sign in
Door Station On and off responses are associated with the DM02 Door Station Module which works with third party intercoms. Some intercoms only turn on the audio when their handset goes offhook. Theses responses allow users to program relays to simulate the intercom handset going offhook and onhook so that the audio can be connected between the intercom and Comfort
dcrera
Status:  Offline
 Posted: Wednesday Nov 28th, 2007 04:30 pm
 Quote  Reply
I downloaded version 2.2.3 becuase I had some problems with the response wizard viz. I could not position Exit Response from a nested If.
After installing 2.2.3, I lost my .ccl file ?
How can I get it back ?
Status:  Offline
 Posted: Thursday Nov 29th, 2007 08:27 am
 Quote  Reply
Comfigurator does not delete any files that was not installed with the program. That is a function of Installshield, the installation program and not of Comfigurator itself.
Perhaps it was accidentally deleted and you can look in your Recycle Bin?
garym999
Status:  Offline
 Posted: Monday Jan 21st, 2008 07:18 am
 Quote  Reply
Glad :) to see comments field added but deos not appear on IF statments, one for 2.2.4. Thanks
ndh
Assisted Living
Status:  Offline
 Posted: Wednesday Apr 2nd, 2008 10:38 am
 Quote  Reply
No ability (I think) to have a  comments only line without exiting the wizard and going manual. If implemented would need delete also.
When testing complex logic it is sometimes good to put the ! in front of a command line to temporarily remove it from processing.
Nigel
Status:  Offline
 Posted: Wednesday Apr 2nd, 2008 02:11 pm
 Quote  Reply
On the contrary, comments line is IN the wizard
ndh
Assisted Living
Status:  Offline
 Posted: Wednesday Apr 2nd, 2008 03:54 pm
 Quote  Reply
Sorry, but I just can't see it!
What Action button and item no. do I use in the Wizard to get the second line here:
Output Output07 On ! Output goes on
! Can't see how to do this line from the Wizard
Omit FrontDoor ! Omit the Front Door
Nigel
Status:  Offline
 Posted: Thursday Apr 3rd, 2008 01:54 pm
 Quote  Reply
You cannot put in a comment by itself on a line.
Comments on each line after an action have been implemented in 2.2.3
if you need to do so I suggest after the wizard when you review the response, go into Manual and add in comments on separate line as needed. At this poimnnt you are in a bettr position to think what coments are needed rather while you are trying to enter the action
Status:  Offline
 Posted: Tuesday Jul 29th, 2008 12:42 pm
 Quote  Reply
Bug discovered in Comfigurator 2.2.3 (probably older versions as well). The use of Timer 64 will cause an "Unknown Exception" Error
If you have used Timer 64 which results in Unknown Exception, use a text editor to change Timer 64 to another timer
 Current time is 10:20 pm
