Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
New Comfort2MQTT for Home Assistant
#1
Hi All,
I decided to take the great work done by @koochyrat and others and update the scripts to integrate a bit more with Home Assistant.
https://github.com/djagerif/comfort2mqtt
A quick disclaimer: I am not a programmer, I tinker a lot, so please don\'t be too critical of this HA Addon. I do have a day job so time, and skill, to figure things out and trying to make it work is limited.
Feel free to test and comment and if there is something that is broken, and I am able to fix it, then I will give it my best shot.
Development was done on an old CM9000-ULT with a Cbus integration. Anything else is a best-effort bonus that I can\'t test or develop for.
The documentation is extensive, I tried to put EVERYTHING in there so if you don\'t understand something, please read the docs again, it should be in there somewhere.
You will need to configure your own flags, sensors, counters, zones etc. I only programmed a few system objects as a start.
Attached Files Thumbnail(s)
#2
Thanks Chiu. Unfortunately my images are not hosted anywhere as they are local to my PC so can\'t be posted by a quick paste. I will add them as files.
#3
Image.
#4
#5
#6
Looks interesting.
I have gone UcmPi (in NodeRed) to MQTT (home assistant) and SHAC to MQTT (home assistant) with two way control.
#7
Hi @Ingo Great piece of work! I have Just loaded this on my system and it works great I get only one error pop up have copied below I dont think it is my config but may be.  I have been using the Koochyrat implementation on a seperate server fom HA for many years and have always wanted to fully integrate with HA but did not have the abilities you do!  Was looking at the @posixx version yesterday and fell foul of the paho-mqtt v2.0.0 incompatibility issues.  By chance saw your work and reconfiguered my MQTT sensors and all is good.  THANK YOU!!Rgds Clive
Traceback (most recent call last): File \"/comfort2/comfort2.py\", line 2877, in <module> mqttc.run() File \"/comfort2/comfort2.py\", line 2443, in run self.publish(ALARMSTATUSTOPIC, SMsg.modename,qos=2,retain=True) # Idle, Alert etc. ^^^^^^^^^^^^^ AttributeError: \'ComfortS_SecurityModeReport\' object has no attribute \'modename\'[/code]
#8
Hi Clive.
I think it is receiving some output of \"S?\" that is not expected. Please send me the output of the S? command and also what model and firmware you are using. Set the logging to debug as this will log all command values, especially the ones just before it throws an exception.
The documentation states only 00 - 03 as return values.
#9
Hi Ingo, appreciate you getting back to me. Here is the log file rgds Clive
2024-10-23 00:07:11 DEBUG r?00F00F000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:27 DEBUG ER00
2024-10-23 00:08:27 INFO Ready To Arm...
2024-10-23 00:08:27 DEBUG SM000140
2024-10-23 00:08:27 DEBUG EX0205
2024-10-23 00:08:31 DEBUG PS00
2024-10-23 00:08:31 DEBUG SM000040
2024-10-23 00:08:31 DEBUG SM000140
2024-10-23 00:08:32 DEBUG MD0203
2024-10-23 00:08:32 INFO Armed Night Mode
2024-10-23 00:08:32 DEBUG AM0903
2024-10-23 00:08:32 DEBUG KL01000000
2024-10-23 00:08:32 DEBUG S?13
mqttc.run()
[23:08:32] WARNING: Halt add-on with exit code 1
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun comfort2mqtt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[00:08:36] WARNING: TLS encryption option disabled.
[00:08:36] INFO: Starting Comfort to MQTT...
2024-10-23 00:08:36 DEBUG Starting new HTTP connection (1): supervisor:80
2024-10-23 00:08:36 DEBUG http://supervisor:80 \"GET /addons/self/info HTTP/11\" 200 9727
2024-10-23 00:08:36 INFO Importing the add-on configuration options
2024-10-23 00:08:36 INFO Completed importing addon configuration options
2024-10-23 00:08:36 DEBUG The following variable values were passed through via the Home Assistant
2024-10-23 00:08:36 DEBUG MQTT_USER = mqttbroker
2024-10-23 00:08:36 DEBUG MQTT_PASSWORD = ******
2024-10-23 00:08:36 DEBUG MQTT_SERVER = 172.30.33.9
2024-10-23 00:08:36 DEBUG MQTT_PROTOCOL = TCP/1883 (Unsecure)
2024-10-23 00:08:36 DEBUG COMFORT_ADDRESS = 192.168.1.77
2024-10-23 00:08:36 DEBUG COMFORT_PORT = 1001
2024-10-23 00:08:36 DEBUG COMFORT_LOGIN_ID = ******
2024-10-23 00:08:36 DEBUG COMFORT_CCLX_FILE = 13MeadowCt_2018_v1.3_DRdis_DSdis.cclx
2024-10-23 00:08:36 DEBUG MQTT_CA_CERT = ca.crt
2024-10-23 00:08:36 DEBUG MQTT_CLIENT_CERT = client.crt
2024-10-23 00:08:36 DEBUG MQTT_CLIENT_KEY = client.key
2024-10-23 00:08:36 DEBUG MQTT_LOG_LEVEL = DEBUG
2024-10-23 00:08:36 DEBUG COMFORT_TIME= False
2024-10-23 00:08:36 WARNING MQTT Transport Layer Security disabled.
2024-10-23 00:08:36 INFO Comfigurator (CCLX) File detected, 236514 Bytes
2024-10-23 00:08:36 INFO Connecting to Comfort (192.168.1.77) on port 1001
2024-10-23 00:08:36 INFO MQTT Broker Connection Success
2024-10-23 00:08:36 DEBUG Subscribed to 16 Zone Outputs
2024-10-23 00:08:36 DEBUG Subscribed to 32 Zone Inputs
2024-10-23 00:08:36 DEBUG Subscribed to 0 RIO Outputs
2024-10-23 00:08:36 DEBUG Subscribed to 254 Flags
2024-10-23 00:08:36 DEBUG Subscribed to 32 Sensors
2024-10-23 00:08:36 DEBUG LU03
2024-10-23 00:08:36 INFO Comfort Login Ok - User 3
2024-10-23 00:08:36 DEBUG Subscribed to 255 Counters
2024-10-23 00:08:36 DEBUG Subscribed to 0 Responses
2024-10-23 00:08:36 DEBUG Synchronizing Comfort Data...
2024-10-23 00:08:36 DEBUG Synchronization Done.
2024-10-23 00:08:41 DEBUG b?00000000000000000000000000
2024-10-23 00:08:41 DEBUG Zones Bypassed: 0
2024-10-23 00:08:41 DEBUG V?FE078C22400100
2024-10-23 00:08:42 INFO Comfort II ULTRA detected (Firmware 7.140)
2024-10-23 00:08:42 DEBUG EL1111FFFFFFFF
2024-10-23 00:08:42 DEBUG 1 Installed SEM(s) detected
2024-10-23 00:08:42 DEBUG Hardware Model CM9000-ULT
2024-10-23 00:08:43 DEBUG DL7FF9045C172F00E2
2024-10-23 00:08:43 DEBUG SN015C172F00
2024-10-23 00:08:43 INFO Refresh Key: 5C172F00
2024-10-23 00:08:43 INFO Serial Number: C086172
2024-10-23 00:08:45 DEBUG M?0203
2024-10-23 00:08:45 INFO Armed Night Mode
2024-10-23 00:08:45 DEBUG Z?00000000
2024-10-23 00:08:45 DEBUG Max. Reported Zones/Inputs: 32
2024-10-23 00:08:45 DEBUG z?000000000000000000000000000000
2024-10-23 00:08:46 DEBUG Max. Reported SCS/RIO Inputs: 120
2024-10-23 00:08:46 DEBUG Y?0E010000
2024-10-23 00:08:46 DEBUG Max. Reported Outputs: 32
2024-10-23 00:08:46 DEBUG y?000000000000000000000000000000
2024-10-23 00:08:48 DEBUG Max. Reported SCS/RIO Outputs: 120
2024-10-23 00:08:48 DEBUG f?00F9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2024-10-23 00:08:50 DEBUG S?00
2024-10-23 00:08:50 DEBUG a?130000000000000000
2024-10-23 00:08:50 DEBUG r?0100100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0110100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?000010FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0010100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0020100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0030100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0040100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0050100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0060100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0070100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0080100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0090100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?00A0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00B0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00C0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00D0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00E0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00F00F000000000000000000000000000000000000000000000000000000000000
#10
Yes, this is the culprit, I\'ll have to investigate this as it\'s undocumented.
I do however notice that you are running a firmware version that is quite old and not tested. I suggest upgrading the firmware to either the latest, or to at least one that has been tested against this Add-on. The minimum is 7.201 if I remember correctly but I personally run the latest 8.013 released earlier this week.
Forum Jump:
Users browsing this thread:
7 Guest(s)
