We have finally found the reason why the UCM/Ethernet sometimes does not connect with Comfigurator.
If Comfigurator is started after the UCM/Ethernet is running, then it works OK
If the Monitor I/O window is not open then there is no such problem. The Monitor I/O window is opened by checking Transfer > Monitor I/O. This allows the communications between the PC and the UCM to be seen,
However, if the Monitor I/O window is open, AND if the UCM/Ethernet is RESET when Comfigurator is open, then it will fail to connect and you will not be able to login or download/upload. Remember that a Reset of Comfort and the UCM takes place after a full download.
The workaround in the above post works. However, an easier solution is to close Comfigurator and open it again after the reset. Or dont open the Monitor I/O window. Now you will be able to connect to the UCM/Ethernet
The reason for this behavior may be in the way Comfigurator opens the TCP/IP port and is being investigated
This problem does not occur with the Comfigurator 3.01
http://www.comfortforums.com/view_topic.php?id=1446&forum_id=20
