Search by username
Comfort Home Automation/ Security System Forums > Comfort > UCM > Upgrading Comfort Firmware via the UCM05
 Moderated by: slychiu, adlim
 New Topic   Reply   Print
Status:  Offline
 Posted: Sunday Nov 4th, 2007 07:00 am
 Quote  Reply
The firmware in the Flash-based MPU
can be upgraded using a UCM05 Universal Communications Module (firmware 5.147 and above) and the Comfigurator software version 2.2.2 and above. It is recommended that UCM firmware 5.156 and above be used for firmware download as it does not require a prior login.
  1. Switch off Comfort and disconnect the battery. Take care that self actuated sirens are silenced before attempting this
  2. When using UCM 5.147 to 5.155, remove the MPU01 module from the Comfort PCB carefully using a flat edge screwdriver or rool to prise each edge from its connector, taking care not to bend the pins. For UCM 5.156 and above, the MPU01 can be left plugged into the Comfort PCB.
  3. Connect the UCM05 to the MPU01 using the UCM05 programming cable
  4. Connect the programming cable (with single 6 cables end) to PP1 on the MPU01
  5. Connect the other ends of the UCM programming cable to the UCM05 that is used for programming to PP1 (with 4 cables end) and PP3 (for 2 cables end).
  6. Switch on the Comfort system. Do not connect the battery. This assumes that the Comfort PCB without the MPU01 has a U1 with older firmware
  7. For UCM 5.147 to 5.155, start Comfigurator, go to Transfer > System Information. Comfigurator will prompt for a user login. Enter the user code. If the user code is not known, Press F0 on te keypad and enter the Engineer code instead. For UCM 5.156 and above skip this step.
  8. Go to Transfer > Firmware Download.
  9. Comfigurator 2.2.0 to 2.2.1 will then prompt for the Engineer Code to be entered. Ensure that the Engineer Sign-in Code option has been enabled (Press F0 on the keypad) and enter the Engineer Code (default 6789). Click on "OK". Comfigurator 2.2.2 and above does not ask for login for firmware download.
  10. Next, Comfigurator will prompt for the file to be downloaded. Navigate to the correct firmware file with the extension .CBF to be downloaded and select it and click "Open". Firmware can only be downloaded when the module has the same firmware type installed. Eg ULT to ULT, You will not be able to download ULT firmware to an OPT
  11. After doing so, Comfigurator will give a warning prompt, informing users that the firmware version will be downloaded. Click on "OK" to proceed with the firmware download.
  12. When completed, switch off Comfort, unplug the cables from MPU01 and plug in the MPU01 to the Comfort board.
  13. Switch on power to Comfort. The voice announcement "Security Off" should be heard
  14. Press F0, go to Engineer Menu by entering Engineer code (default 6789) and # key, and press 7,4,3 for System information. The correct Firmware version should be announced
 Current time is 04:11 pm
