Comfigurator 2.9.1-2.9.9 Beta - Printable Version
+---- Thread: Comfigurator 2.9.1-2.9.9 Beta (/thread-1088.html)
Pages: 1 2 3 4 5
- admin - 08-24-2008
The new version of Comfigurator Beta 2.9.4 is available
All the features have been implemented and known bugs fixed
Support for Enocean and Miracle/HDL have been implmented in UCMs
- slychiu - 09-13-2008
Comfigurator Beta 2.9.5 is now available
This fixes bugs from previous versions
- admin - 09-30-2008
Comfigurator 2.9.6 is now ready for download, with more bug fixes
- slychiu - 11-06-2008
Comfigurator Beta 2.9.7 is now available for download from here
http://www.cytech-technology.com/temp/software/Comfigurator2.9.7.zip
This version fixes bugs found so far
Please feedback bugs and findings to this forum or email to support@cytech.biz
- koutsogiannis - 11-06-2008
The issue Comfigurator 2.9.x Beta, I can say that corrected many details as the ease of reference in planning, especially when the installer had volume (automation facilities)
What I need to add is that the installer time plans to perform test of the mandate. Example: Send X10 - IR   or to hear from keyboards the tone horn chosen.
These broadly. I believe that this publication will help a lot
- slychiu - 11-07-2008
If I understand you correctly, you would like to be able to send the X10 and IR and simulate the siren sounds when you do programming
You can do this by Using the Execute Response function where the Comfort system will  do the response you have programmed, including Xx10, IR and activate the siren type chosen. You will still need to do a download though
- juwi_uk - 12-06-2008
Hi everyone,
I downloaded the Beta 2.9.6 from the website today and tried to install.  My Avast virus checker said it was infected with a trojan so I aborted the install.  Downloaded it again just to be sure and same happened again.
I tried the 2.9.7 from this thread and it\'s ok.
Suggest you might want to check 2.9.6 yourselves but I\'d say it could well be suspect! Sad
- slychiu - 12-07-2008
Strange, I just checked with Zone Alarm antivirus and it did not report any infections. What was the trojan reported do you know?
I have removed the old links, as 2.9.8 will be out soon
- juwi_uk - 12-07-2008
Avast reports it as \"Win32:Trojan-gen {Other}\".  Could be Avast being over-sensitive to the setup.exe file but it thinks its a virus/worm.   Build 2.9.7 doesn\'t do this so must be some difference between the builds at least.
- slychiu - 12-09-2008
I suspect Avast is  a wee bit sensitive. Let us know if it happens for future versions
regards
