Android Phone App 1.08 Beta - Printable Version
+---- Forum: Android Apps - 1st generation (https://www.comfortforums.com/forum-121.html)
+---- Thread: Android Phone App 1.08 Beta (/thread-3196.html)
Pages: 1 2 3
- wexfordman - 12-11-2012
Hi, any update?
- ident - 12-12-2012
we are still working on it, no update yet
- Ingo - 12-12-2012
I also ran the Android App through my Simulator and saw that the CM commands do go out to the network. From this side it just looks like the cm replies are not being actioned.
Ingo
- tman - 12-12-2012
Is there any way of disabling the button press \"clack\" sound?
- waynebr - 12-12-2012
Hi can someone explain how I get the comfigurator file loaded into this app. I have tried a samsung galaxy s2 & s3, followed the instructions and got it emailed to me then opened it and it asked me to select the profile to use.
I get confirmation confirming it was selected and then nothing. It does not ask me to log in or even open the app. If I then go and open the app and input my login it connects to the system but I cannot see any zone information or home control menus.
I have tried uninstalling and reinstalling and updating to latest firmware as above but nothing works.
I managed to get it onto the S2 after many attempts using the old app but it only did it once and I could not replicate it.
Don\'t know what I have done but it just started working SmileI haven\'t finished programming so will try again once I have made changes.
Quote:I get confirmation confirming it was selected and then nothing. It does not ask me to log in or even open the app. If I then go and open the app and input my login it connects to the system but I cannot see any zone information or home control menus.
We have  noticed this
When you import a file into an exiting configuration, the zones and control menu cannot be seen.
What you need to do is go into the config and  EDIT the config, then OK and log in
You will see the zones and control menu
Quote:Is there any way of disabling the button press \"clack\" sound?
Maybe we can find a better sound. disable means you may not know if the button is pressed, sound gives a good feedback
- Ingo - 12-12-2012
How about an option of Sound, Vibration and Sound or Vibration only? All selectable in the configuration menu.
- slychiu - 12-12-2012
We certainly would like to, but it has not been a smooth experience getting things done for this android app as you can see by the time it has taken
It is not satisfactory at all
