Threads: 880
You should see the status update fast on the Tablet app version 1.85 also, with the new UCM and Comfort firmware
Import the cclx file into both apps
Threads: 64
12-09-2012, 09:27 AM
(This post was last modified: 12-09-2012, 09:32 AM by wexfordman.)
I already had both ucm eth01 and comfort firmware upgraded earlier in the week using the new version of comfigurator.
Anydroid app still very slow on my HTC one x.
Even when I turn on a light, the light goes on but app does not show New status even after 60secs.
Scs values are intermittent in reporting back temps, and sometimes. Don\'t report back at all
Threads: 880
can you compare directly to the iPhone app with the same file?
How slow do you mjean? Does the status appear after seconds, or minutes ?
What is the android OS version?
Can you try deleting the app and reinstalling?
Threads: 64
12-09-2012, 09:43 AM
(This post was last modified: 12-09-2012, 09:45 AM by wexfordman.)
Just un installed and reinstalled the app and configuration file. No change in response times, and not updating status of lights at all. Iphone app working fine.
I can see pir sensors activate and clear down but the control menu is either not updating or incredibly slow.
I can send you on my conversion file and settings to demonstrate for yourselves if you want, let me know the email address.
My android version is 4.04 and by slow I mean either minutes or not at all.
Threads: 62
I am also not seeing my Control Menu updating... The light goes On but shows it still in Off state in Control Menu.
Running Android 2.3 on HTC Desire.
Ingo
Threads: 64
12-09-2012, 07:22 PM
(This post was last modified: 12-09-2012, 07:32 PM by wexfordman.)
Just to update, I double checked my firmware, and noticed comfort was at 6.028, and eth was at 7.02!!
I was sure I had updated to latest fw, but as 7.05 was beta, it had not picked up and told me i was latest fw.
anyway, i upraded comfort to the beta fw, and checked everything again, but no change, still having same problems.
Sorry for confusion!
I also, created a new conversion file from and added it to my app, but also no change. Its odd, I get some device reporting back but others just blank, for example 1 scs reported back temp settings, the others remained blank!
Threads: 62
Some feedback from my side. I have two UCM\'s and connecting the one using Android and the other with Comfigurator I can see the bus messages.
On initial Android login, and pressing the Control menu, there are no CM command messages to query the COntrol Menu status. This morning however when I press either the On of Off menu options does update. This is not consistent though as wexfordman has also noticed.
When executing my Response manually I can see th CM command reply come in but the Android App doesn\'t respond to it, the status doesn\'t update.
Ingo
ULT7.005/UCM7.002
Threads: 880
we are tracking down this problem and should have a fix soon
