Bypassing a zone - Printable Version
+--- Thread: Bypassing a zone (/thread-1962.html)
Pages: 1 2 3 4
- TheMax74 - 08-23-2010
There is an italian vocabulary for comfort too.
Answering machine will speak announces in italian.
- emabonacchi - 08-23-2010
Where can i find it?
Ask Chiu or an Admin.
Wink
- slychiu - 08-24-2010
The italian voice can be found at http://www.comfortforums.com/view_topic.php?id=1666&forum_id=25&highlight=italian
You need to use Comfigurator 3 and a UCM for this.
The Comfort firmware should first be upgraded to the new version 5.212 see http://www.comfortforums.com/view_topic.php?id=1970&forum_id=79&jump_to=7915#p7915 as the later versions improve the vocabulary upgrade process to reduce errors
- emabonacchi - 08-24-2010
Trying to update the firmware i receive a message -DUT is not connected-.
What does it means?
It means that the programmming cable is not connected, see the instructions for firmware upgrading in http://www.comfortforums.com/forum4/1216.html
I have bought a new pc, so now i can use comfigurator3.
I have updated the firmware and installed the new voice.
Now, X10 commands are not more received and sent... obviously, now i am in the panic....
Check your program again, se if theer is any problem in the conversion
Have you done write to Comfort wityhe the cclx file?
Sure. I have writted the cclx file and not the ccl file.
And now i have another problem.... this message on the lcd screen
 Text wrong push#1 togheter
Then a message  Downloading, but many minutes passed and nothing happens.....
I have done a bad thing trying to update the system i think.....
After resetting the system again and again, x10 does works again, but on the lcd screen of the keypads, i have still the same problem.
