Comfigurator 3.8.6/3.8.7/3.8.8 - Printable Version
+---- Thread: Comfigurator 3.8.6/3.8.7/3.8.8 (/thread-3777.html)
Pages: 1 2 3 4
- mikegriff - 06-17-2014
So how do i enter 255 in a trigger group?Mike
- Ingo - 06-17-2014
You have to manually edit it. \'15,253\' is 255.
197,19,5,202,0,2,150,15,253,255.
If I put that into Comfigurator 3.8.8
I get a response Error
Invalid Action Selector:Cbus UCM-Cbus 202 150 2,255
Can someone confirm that they can put 255 as a level into Cbus trigger level from Comfigurator 3.8.8
either by the Response Wizard 255OR
Editing the Action Codes
Thanks in advance
Mike
- Ingo - 06-17-2014
Sorry if I was not clear enough in my previous post, you have to edit the CCLX file manually.
ActionCodeString=\"197,19,5,202,0,2,150,15,253, 255\"
The problem is that the Decode routine in Comfigurator might change it back again if you do another save. I have converted from Cbus to Cbus2 using Comfigurator 3.8.6 and manually updated the ones that were \'not supported\'. Since then I\'ve made no changes in fear of my changes being undone. Once 3.8.9 is out I hope it will not mess up my changes. It\'s always good to keep a backup cclx file just in case.
I see
do you change just that line or both?
ActionCodeString=\"197,19,5,202,0,2,152,[color=\"#ff5500\"]254[/color], 255\">
      <ActionSource>
        <string>Cbus2 UCM-Cbus 202 152 2,[color=\"#ff5500\"]254[/color]</string>
Thanks for your help
Mike
- Ingo - 06-17-2014
Try by just doing the first line, that is the actual command. The second is what Comfigurator displays.
Just remember to revisit your manual changes once 3.8.9 is out.
Thanks for your help Ingo
I\'m also going to try mapping the counters as a fix
Mike
- mikegriff - 10-30-2014
Hi All
Was the 255 issue with the Trigger Group ever sorted?
Thanks in Advance.
Mike
- Ingo - 10-30-2014
I believe is still broken.
- slychiu - 10-30-2014
I thought it had been fixed
Is the problem that the Trigger actions do not work at all or they do not work for a certain action selector??
we do limited testing for triggers as we dont have any device which has these triggers, which seem to be overly complicated
