External Power - Printable Version
+--- Forum: FAQs - Technical (https://www.comfortforums.com/forum-16.html)
+--- Thread: External Power (/thread-4308.html)
Pages: 1 2 3
- slychiu - 08-30-2024
SCS leds stop when the leds get a command to turn on or off. I would look at your scs responses
- Swiss-Toni - 08-30-2024
[user=1]slychiu[/user] wrote:
Quote:SCS leds stop when the leds get a command to turn on or off. I would look at your scs responses
 The issue is that comfigurator now does not give you the option to do scs resposes, this is using the latest version of comfigurator I need the range up to 200+ not starting at 200+
 Because of this I cannot programme the RIO01 or the SCS switches 4 X RIO01 & 7 X SCS6 switche. Even using original file that was working previously it will not allow for it to work. Is it possible the NVM IC could be the issue Im sure there is a back up wich I will swop around if I have it
in Comfigurator can you go to File > Update Defaults. Then restartr comfigurator/ This fixes a configration error in RIO/SCS
T
That fixed virtually every fault after hours of head scratching ha ha ha ha, thank you Wink
yes we documented here http://www.comfortforums.com/forum84/5500.html
