Comfigurator 2.9.1-2.9.9 Beta - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Comfigurator 2.9.1-2.9.9 Beta (/thread-1088.html) |
- admin - 01-04-2009 [user=876]juwi_uk[/user] wrote: Quote:Getting an issue with 2.9.8 and Smartfit config. Works Ok in 2.2.3.I cannot make out the error in the screenshot, the resolution is not good enough I opened the smartfit.ccl demo file and did not get an error. However I am using 2.9.9 which is now available from https://www.cytech.biz/Default.aspx?cmd=sQ0OYE9X66w%2b0P%2bAcFsmAI3j73Rwtfrj&fileid=203&dcid=4&pageindex= so please try it as it may have been something that was fixed in this version - admin - 01-04-2009 [user=876]juwi_uk[/user] wrote: Quote:Getting this error on opening my CCLX file. Any way to get out of? I just deleted a response and got this error. I chose not to SAVE on exit but still got when I reopened file (so did it save anyway...?).Please try 2.9.9 linked in the above post. If you still have the same error, send the cclx file to support@cytech.biz - juwi_uk - 01-04-2009 Hi Chui Nope tried 2.9.9 and it still gives the error when opening the file. I can send to you dircet if you let me know how to do securely. I\'m julian@wigman.me.uk if you want to email me. J - juwi_uk - 01-04-2009 Chiu, It still is broken on 2.9.9. I\'d upload the smartfitdemo config but the website doesn\'t allow me to attach cclx files at the moment (just lost all the content of my previous message which trashed as I found this out when I submitted!!) If you open the file and look at response 158 (\"Smartfit OverrideHeatingSP 2 26 2\") the Response Errors panel says \"Invalid Syntax: Smartfit OverrideHeatingSP 2 26 2\". Look at reponse 156 though (\"Smartfit QueryHWTemp 2\") and this one is fine. Tried recreating in the wizard and get the same errors. Tried cutting and pasting the Action codes from my old ccl to the cclx and this time it changed them to \"Send RS232...\" format. Works fine in 2.2.3 though. Any ideas. I can send CCLX to you directly if you want. Better you fix the website upload option though ![]() (I\'m using Vista Ultimate 64bit fully patched OS). J - juwi_uk - 01-04-2009 Bigger screeenshot of Error attached - admin - 01-05-2009 The error has been found and will be fixed in the next version. cclx and cctx files are now accepted as attachments - juwi_uk - 01-09-2009 Any news on when the next version of Comfigurator will be available (ie > 2.9.9) ? - admin - 01-09-2009 Actually 2.9.9 is already available on the download site, I forgot to announce - juwi_uk - 01-09-2009 I actually want one after 2.9.9 that is promised to fix my Smartfit issues. Regards Julian - juwi_uk - 01-10-2009 Interesting errors when setting sunrise/sunset times with v2.9.9. Steps to reproduce as below:
Regards J[font=\"Times New Roman\"] [/font] |
