Comfigurator 3.8.6/3.8.7/3.8.8 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Comfigurator 3.8.6/3.8.7/3.8.8 (/thread-3777.html) |
- Ingo - 10-30-2014 It is only a problem when selection an Action Selector value of 255. If you manually edit the cclx file and add 15,253 then the response works. The Response Wizard unfortunately doesn\'t understand this and gives an error if you try it via the \'Manual Edit\' option. - slychiu - 10-31-2014 Thanks, it should fixed in the next version. I dont know why it was missed out - mikegriff - 10-31-2014 Brilliant Thanks |
