Comfort Date is out by 1 day - Printable Version
+---- Thread: Comfort Date is out by 1 day (/thread-4502.html)
- slychiu - 09-01-2016
Problem
Comfort Date is out by one day but time is correct
This could lead to Time Programs activating on the wrong day
The Comfort Date can be seen on the LCD keypad
Do a Set Comfort Date and Time and immediatetly check that the date and time is correct. If it is not correct, then the date and /or time in your PC is incorrect
If the date and time is correct after updating from Comfigurator;
Is there a UCM/ETH03 in the system?
This has a feature of automatically updating date and time from an Internet server
see http://www.comfortforums.com/forum113/3695.html
There is a bug in ETH03 2.14 where the dates in 2016 are wrong. see http://www.comfortforums.com/forum113/3904.html
Upgrade the ETH03 firmware to 2.20 (or the latest) to fix this problem
Also ensure that the Comfort server manager software is updated, as well as the UCM Firmware
