Pir Pulse
If i Have A PIR BAthroom 1 As my ZONE 6  Door Window input, And i Want to PULSE A C-Bus GRoup Adress For The DURATION of the Pulse. How And Where Do i Do it. The Counters i Take it is All The CBus Group Adresses Or Not ? What i Am Trying To Acheive is.. if a PIR in The House is Activated The Cbus  Will Set A Specified GA On For 2 Seconds. Then Off. Not Sure How To Do it . Any help.Cool
Instead of setting your PIR bathroom as DoorWindow zone type, I suggest that you set your PIR bathroom as PIRAway (activated only in Away mode) or PIRNightAway (activated in Night and Away) zone type.
If it is set as DoorWindow zone type and the system is armed to day mode (in which there are still people inside the house) and somebody walks into the bathroom, the PIR will sense a movement and will trigger the intruder alarm.
The group addresses on C-bus are mapped into Comfort\'s Counter ranging from number 0 to 254.
For turning on a specific group address upon activation of PIR, create a response under Zone 6 On Response (in Comfigurator > Security > Zones/Inputs) with the following actions:
   [color=\"blue\"]CBUS On 2 12
   Do Address12Off [turn off group address 12] After 2 Seconds Using Timer01
[/color]
where the actions for \"Address12Off\" response would be:
  [color=\"blue\"] CBUS Off 2 12[/color]
In the example above, triggering of the PIR will turn on group address 12 (2 is the UCM/Cbus ID) and then will call another response (Address12Off) to turn it off after 2 seconds.
Thanks For The Reply. But now i Have Something elese Thats A Problem Comfigurator is Askeing Me For A Engineer Code And Press F0 On Keypad ,, I Dont Have A Keypad, What Do i Do? Also in Response To You Mentioning Me To Change the PIR Setting To Away. What i Want To Do is Only use the PIR in Day Mde Anyway But The Intruder in Away Mode.
Oh i Forgot To Mention i Can upload using the MindIIT Software V 2.0 using Code 1234 But under Comfigurator i Changed It To 8779 And When i Type That in The F0 Engineers Code it Say Not A user password , Wants A Engineers Code. Help Got Rainy Weatehr Here isn SA CApe And Lots of Programming Time But Cant Upload to Test.He He . Also SAy For Example i Have The Following ZONE 6=PIRBath1 And i Want to PUSLE Group Adress In Sec>Zones/inp To On. AND AS Soon As the PIr Stops Detecting Motion In The Off Response On ZONE 6 It Must Set GRoup Adress PIRBath1 To Off. The Timer 01 Thing I Dont Get It Yet.  I Am Trying To Get the Basis For A System Where if Baathroom PIR Is On the n Pulse Lights On If PIR Bathroom1 is Off Set Lights Off Senario. From There i Will Program The Rest into Clipsal Logic Engine....
If you do not have a keypad, then are you using the MinderPro as an alarm system? Presumably not because you need a keypad in order to arm, disarm and hear or see the open zones when you want to arm the system. You may have a keypad emulation on CTouch but that is not battery backed up so it has limitations as a proper alarm keypad. Disarming from a Cbus switch is not a good practice because of the security risk. If the alarm side is not important and there is no chance of break-in in the house, then that may not be a problem. I suggest that you add at leat one keypad to provide better security It does not cost much but can prevent many problems in security
You can upload and download without pressing F0 by going to Transfer>  System Information to open the Monitor I/O window
Then in the window type DA5C01. This enables Engineer Menu. You can nopw do an upload/download without ptressing F0, just enter Engineer code
I am agraid I cant work out the rest of your questions. Can you put in some puntuation please.
Thanks You For Your Reply, The Security Side of The Minder/Comfort is importatn To Me, However It Has A Battery Backup on the Whole House. For now I Hqave To use A Group Adress To Arm Disarm On a A Touch Screen ( Password Protected ) . i Would like to Get A Keypad Eventualy, Finances Permitting.
I Will Try the Remedy You Suggest And Upload my Configuration. Appologies For the Punctuation, It Was Edited Late At Night. Thanks You For Your input So Far.Big Grin
Hi there I Have just Tried To Do The DA5C01 Fix But no Joy It Is Still Asking To PresF0 On Keypad And Enginers Code. Is there A Default Engineers Code As i have not Adjusted This?
Engineer code is 6789 default
Ignore the F0 key and enter 6789 as the engineer code
:? i Get A invalid Login... Whould it Help if i reinstalled Comfigurator And Uploaded Then?
No it is no use to reinstall Comfigurator
Step by step again
  1. Transfer > Monitor I/O - check this
  2. Do Transfer > System Information
  3. The system will ask for a user sign in
  4. The Monitor I/O window will open and the system information is displayed
  5. In the Monitor I/O window, type DA5C01.  You should get a reply RA..
  6. Now do the Transfer PC > Comfort.
  7. The screen says Press F0 and Enter Engineer Code
  8. Enter 6789 and press OK
  9. The transfer should start
If anything does not work describe the response at each step what did not happen
In reality Comfort was actually designed to work with a keypad not without it. You will encounter many other problems if you do not have one so be forewarned.  I advise you again to get a keypad. It is essential for a security system not optional
regards
Tx: <STX>DA501<CR>
RRx: <STX>IP0300<CR>
No Luck, Going to order Keypad x2 On Monday
Thnaks For Help Have A Wonderful Weekend. Thanks Again.
Clinton
