08-15-2006, 02:22 AM
Check to see if font smoothing is enabled on the PC, if so, uncheck the box and redownload the file to the KT01.
Font smoothing is in \"Display Properties -> Appearance ->Effects\", uncheck the option \"Use the following method to smooth edges of screen fonts\".
Once you\'ve done this just download the file to the screen again - no need to change anything on the screen set up.
