07-25-2009, 11:37 AM
The I/O monitor is an excellent diagnostics tool. Is it possible to allow acces via the UCM/ETH rather than just the RS232 port?
I/O Monitor
07-25-2009, 03:42 PM
Use Comfigurator 3 as it\'s already built into that and works over ethernet.
J
07-26-2009, 03:20 AM
Well even in Comfigurator 2, the I/O Monitor can be used over Ethernet if you have select Ethernet in the Connections options
Do you mean the Comfort Bus Monitor, which is a different program which monitors the Comfort RS485 Bus? There is a Virtual Serial Port software included in the new UCM/Ethernet Device Server Toolkitwhich maps a Ethernet IP address and Port to a serial port but unfortunately the Bus monitor produces too much traffic for the network and jams it up, so nothing appears |
| 2 Guest(s) |
