Threads: 55
Hello, i would report that when i read from EEPROM, i need to do this twice.
First time, the reading process is fast, but it reads almost all \"NULL 0/0\" in the \"KNX to Comfort\" tab.
Second time, it takes a while, but it reads all settings in the right way.
KNX 5.192
UCM05 5.178
Ultra II 5.164
Thanks.
Threads: 262
See what happen when you upgrade the UCM05 to 5.192
Threads: 55
07-29-2009, 01:39 PM
(This post was last modified: 07-29-2009, 01:40 PM by TheMax74.)
Ops... sorry! I\'ve not noticed that UCM05 has a new 5.192 firmware, because KNX has the same firmware number 5.192, so i maded a mistake.
Will try this evening. Thanks.
Threads: 55
Ok, no more errors.
Seems it works good now.
Thank you
Threads: 262
Actually, Read from EEPROM still has a problem due to Comfigurator up to 3.1.0
A new version will be available soon which fixes this
The Read problem only occurs if you Reset to Default in the KNX to Comfort Screen and make it blank. This is why it works the 2nd time
Threads: 885
The problem with READ fdrom EEPROM sometimes coming up with blank data has been fixed in Comfigurator 3.1.1
