10-29-2009, 09:10 AM
Yesterday I upgraded the Comfort Firmware to 5.169 and am using Config 3.1.3 I also upgraded the voice to Kate29 and re recorded all the reminders.
There are 2 Fermax Door Stations, via two DM01\'s and 4 keypads. The file system is 34, system Vocab version 29 Version 1
Before the upgrade all was working fine, but now I find that the Reminders specified to play on Door stations only, are played on all keypads and door stations. I changed the instruction, in this response, to play on just 1 keypad and that was fine. I then did the same for each keypad and each time it played on the one specified. BUT as soon as i specify either one or both of the door stations, the reminder is played on everything. has anyone else had a problem like this? Graham
hock:
hock:
