Threads: 7
08-26-2006, 03:27 PM
(This post was last modified: 08-26-2006, 03:27 PM by Majik.)
I\'ve had Comfort II in and running for about 6 weeks now, replacing my Comfort I system.
One thing I have noticed is that the keypad backlights seem to stay on all the time when the system is in \"Security Off\" mode. When armed (at least when armed to \"night\" mode) the lights go off.
I\'ve checked the keypads and J4 is set to \"Normal\", and they haven\'t been changed at all since I converted from Comfort I.
Has anyone else noticed this?
I\'m using firmware 5.054.
regards,
Keith
Threads: 0
To have a better understanding of your problem, does it occur only when you change to security off mode?
How about pressing \"#\" key in security off mode? Is the backlight still on?
Threads: 7
Yes it does only happen when moving to security off, and after I press the # key it eventually goes out.
Cheers,
Keith
Threads: 0
I suspect that there is a long \"to do\" list (like switching on lights etc) when changing to security off mode.
One possible solution is to separate all items in the \"to do\" list into 2 parts and trigger each other with a time interval (maybe 2 seconds). In other words, upon changing to security off mode, the response will trigger 1st part of the list and a timer to trigger the rest later.
See if the problem still exists.
Threads: 7
I wouldn\'t call it a \"long\" list:
Stops a timer
Limit dialout
sets a flag (via a do)
Issues 2 X10 commands (via a nested do)
I\'ll try setting the X10 commands to be triggered by a time as you suggest and let you know how it goes.
Cheers,
Keith
Threads: 7
OK, I tried this but no dice. My SecurityOff response now reads:
Stop Timer LightFlash
Limit DialOut
Do CamPersistOff [Set Camera Persistance OFF]
Do Heat21C [Heating to 21C] After 5 Seconds Using Timer14
In case you were wondering, CamPersistOff reads:
Clear Flag CamAlwaysOn
But I still get the keypad light staying on until I press the # key
Any other ideas?
Cheers,
Keith
Threads: 880
This may be an unintended consequence of a chnage we made to fix another problem, where when the system is disarmed, the backlight was turned off immediately, which is inconvenient when it is dark
We will investigate and see how this can be improved in the future
Threads: 7
08-30-2006, 07:40 AM
(This post was last modified: 08-30-2006, 07:40 AM by Majik.)
I tweaked the response further trimming it to:
Limit DialOut
Do Heat21C [Heating to 21C] After 5 Seconds Using GeneralTimer
(so the CamAlwaysONn flag is unset directly rather than via the do CamPersistOff response)
It now seems to work OK.
It does seem to be very sensitive!
Cheers,
Keith
