What have I broken?
I have Comfort Ultra 1 with (firmware 4.227) and while making a few changes to the AC restore location (we have a lot of power failures), I changed location 400 response. I think I broke something, the only difference I have observed is when a power failure occurs I hear a long beep instead of multiple beeps over the same period.
Any idea what location 400 response should be?
Mohau
Location 400 default value should be 4
You can also use Comfigurator 3 and do a selective write for Sound Types and Siren Types to restore these parameters back to their default values
Even if you dont use Comfiugrator, it shows you the locations and the values, eg Open the default file for your Comfort I Ultra,  Go to Security Types > Sound Types > Sound Types 3. The bottom left shows
(399) = 74, 4,0,4, 128
This means location 399 = 74, 400 = 4, 401 = 0, 402 = 4, 403 =128
The AC Restore Location is 736
In Events > Misc Events see AC Restore Response. The location of the Response is given in the bottom left. Response numbers are 2 bytes (low byte followed by high byte)
Changed it back to 4, thanks for your help.
