Using Comfigurator 3.1.8 to program a Comfort Pro 4.17.
A response to check the security mode of comfort, then set a C-Bus group to a predetermined level appear to match all conditions as true.
Whenever I run the following response, I see the CBus group ramp 0,1,2,3 instead of setting the correct level.
If SecurityMode = SecurityOff Then
CBus RampInst 2 50 0
Else
If SecurityMode = AwayMode Then
CBus RampInst 2 50 1
Else
If SecurityMode = NightMode Then
CBus RampInst 2 50 2
Else
If SecurityMode = DayMode Then
CBus RampInst 2 50 3
EndIf
EndIf
EndIf
EndIf
Else
Else
Else
EndIf
EndIf
EndIf
EndIf
