The new beta version of Comfigurator is now availalble at http://www.cytech-technology.com/temp/so...r3.2.2.zip
Comfigurator 3.1.9 is still the current released version
New Features
New Features
- IFR files are now installed to ProgramData folder to allow writing by IR utility so that it can work in Windows 7
- Allow 330 Velbus to Comfort entries
- IR Learner and Bus Monitor have been incorporated into Comfigurator so the port does not need to be specified separately, but this feature is still under testing. Use the stand-alone versions of Bus Monitor 1.0.2 at Comfort Bus Monitor Link and for IR Learner 1.2.3 at http://www.cytech-technology.com/temp/so...frared.zip
- Clear zone virtual flag when deleting or changing type of KNX To Comfort address mapped to virtual input.
- Omit spurious counter properties for ZWave controllers
- Omit used counters in dropdowns for ZWave channels 2-8
- Fix missing ZoneState elements on reading from KT03
- Fix error in decoding special page references on reading from KT03
- Fix error in encoding KT03 clock element
- Tools > IR Learner and Bus Monitor are for testing, may cause exceptions.
- Read from Comfort with Keep Names Options causes Exception. Dont check \"Keep Names\" when doing Read from Comfort
- Double-clicking Number of Slaves in Modules & Settings causes an exception
- Right click on an empty Response will cause an Exception.
- Opening a Recent File which has been deleted causes an Exception
- IR Receive Responses - if assigned to NULL, will call Response 255 if the IR signal is received. To workaround, do not use Response Number 255
