CCTV
I want to connect a CCTV to my comfort system.  Do you have any reccommendations on equipment and how to integrate it with the house security system.
CCTV is really independent from Comfort. Comfort does not handle video directly, and is mainly about control, security and voice.
If you use an IP camera or Digital Video system, these have their own system and software for viewing over the network and the Internet, and may require software plug-ins etc.
The CWM is able to work with IP cameras in that you can place an icon for the IP camera on the CWM page so that clicking the camera icon opens the camera image on the browser, but here Comfort does not handle the video at all
If you use the DS01 and DS02 with the camera option, this has camera with video output which can be conected by a RG59 cable to a monitor or TV video input. When the doorbell is pressd, then the video can be seen when the audio intercom is in operation.  Here the video is not handled by Comfort, it is a sepearate connection to the video display
I hope this clarifies the issue
ComfortClient can also handle an IP Video stream. Just create a Browser Floorplan and point the browser to the URL of the camera/DVR. We haven\'t yet had a request for ComfortClient control direct from Comfort itself but having the Client sound a bell and then auto-navigate the \'Camera Floorplan\' seems like something worthwhile. Will add it to the list and discuss with Julian to see if it\'s possible.
There is one exception though, it doesn\'t load all custom viewers yet especially if you use a 64-bit browser. Search the forum for ComfortClient, I am sure there was a link to an online camera for a Hotel in the US.
The 64-bit support is on the list to be implemented but it will take some time to get there because of the complete engine rewrite that Julian is busy with. I also think that the problem is not with the Client itself, it might be a Microsoft issue on their 64-bit browsers.
Ingo
I compile the ComfortClient with the \"AnyCPU\" option set which means if you run the Client on a X64 bit OS it runs as a  64 bit app. and if you run on a x86 OS it runs as 32 bit.  As a consequence the x64 bit version runs the IE x64 browser and the x86 version runs IE 32 bit browser when you add a browser tab in the Client.
Whilst the normal 32 bit (x86) IE browser runs many plugins,  the x64 bit IE has more patchy (but growing all the time) support based mainly on the facts that it is (a) newer and (b) mandates that plugins are (certificate) signed.
The webcam link Ingo mentions is one java x64 based plugin I\'ve tried in the Client and it gives you buttons to control the camera which was good.  http://comfortinnbelfast.com/web-cam
Also recenty into Beta is a ActiveX Flash x64 plugin (square) you can find at http://labs.adobe.com/downloads/flashplayer10.html and this seems to test out OK in the client. I used this test in the Client as demos animation and video Flash tests:  http://www.chemgapedia.de/vsengine/info/...flash.html
I guess control of the CCTV camera really boils down to the specifics off the manufacturers camera software and what plugins it supports/provides.
I\'m happy to try and add some support to the Client if we can define what that is and it isn\'t too proprietary.
In version 2 of the ComfortClient,  due soon, I also plan to compile individual 32 and 64 bit versions such that even on 64 bit OS you can still install the 32 bit version if you wanted IE plugin support not available in IE 64.
p.s attachments show the 64 bit Java and Activex plugins I tested in IE in the ComfortClient.
Visit http://www.gbsdvr.com/ for buying a good security camera.
