01-05-2011, 03:24 PM
Activity Tab indicators shows a user all activities in ComfortClient. If you have one floorplan open and another tab starts to flash a certain colour then you know something is happening there. Different colours also indicate what possible activity it might be.
Let\'s take a light being switched on, that can be a CounterFlag object or a Counter to indicate the level of dimming that changed. The default values for those objects are to use the \'Auto\' setting. These are defined in the Activity Level Settings.
Instead of changing all your CounterFlag objects manually from EG. Level-2 to Level-3, you can change the defaults and all those object types will change if they are using the \'Auto\' mode. You can still change them individually but if you have lots of them then it might take some time.
Go to Configuration->Settings->Activity Level Monitoring and make your changes there. Keep in mind that these are the default values. If you need a certain level for a particular object then you can change it in the Object Properties itself.
Take note that this is all changing the default values used and is different from the Floorplan Editor \'Bulk Activity Change\' function. That function is to change the actual levels of the objects. In short, if you have Counter objects at their default \'Auto\' setting and you wanted to hard-code them all to Level-3 then this is where you would do it.
