Send Date/Time to Velbus
I disconnected the power to my Velbus network.
When powered back on the time was incorrect on the VMB1TC.
Send Date/Time to Velbus is selected on the UCM/Velbus properties.
After 12 hours the time has not updated on the VMB1TC.
How often does Comfort send out the time and date?
Hi, Bs85
Sorry! It\'s a firmware bug, I believe no module with address 0 in your Velbus network, temporary you can put any module\'s address to be 0, then this function should be OK, we will update it together adding other new function in next firmware release!
There is a VMB4PD at address 0
The VMB1TC is set as master clock not the VMB4PD
ok, you can swap the address of this 2 modules, the problem is when we release velbus firmware,velbus man just release VelbusLink software v6.0, which is not support VMB1TC, so we didn\'t include this module,so next time we will also include it! thanks!
