05-27-2011, 10:59 PM
Hi Everyone,
I\'m pleased to release 2.1.1.66 of ComfortClient to resolve some issues that Aaron, Brian and Ingo have found recently. IT can be downloaded from:
http://www.comfortforums.com/forum65/1948.html
and has the following fixes:
Quote:Bug Fixes/ChangesRegards
- Added Event Log decodes for Event Codes 27 ââ¬â 33 as added in a recent firmware update.
- In Floorplan Editor Object properties, the ââ¬Åimage layout typeââ¬Â for a gauge with background image defined did not populate the dropdown list correctly.
- Saving a gauge design to a GaugePack in Floorplan Editor, incorrectly added the ââ¬ÅImages\\ââ¬Â folder path to the gauge background image file name saved in the file. This created an exception if the gauge was then used again during the same editor session. Note: If you created any GaugePacks in version 2.1.1.65 which also include background images then you need to edit the file manually correct these or else the Image will be ignored at load; i.e. if the entry reads BackgroundImage=\"Images\\myImage.jpg[/i]\" then change to BackgroundImage=\"myImage.jpg[/i]\".
- Installing ComfortClient without samples did not create the ââ¬ÅConfigsââ¬Â folder in new installations.
