07-27-2011, 08:51 PM
All,
This thread is for the forthcoming Version 3 of the ComfortClient.
Version 3.1.1.x makes the jump to .NET 4 so you will need to install the .NET 4 Client Framework to use this version of ComfortClient.
This version has a number of new features already including:
In the meantime Ingo and I will post some taster screenshots.
- Support for a new Linear Gauge Floorplan object
- Support for both UCM/USB and USB/232 connections
- Copy to Clipboard for Monitor and Event Log windows
- Monitor Log pause button
- Fonts and Text rotation on Circular and Linear Gauges
- Better recovery on connection loss to UCM
- Colour coded entries on Event Log decode
- Eventlog can now be saved to DOCX and RTF formats
- Check for other existing connections to Tibbo interface in Network Connector
- Most Recently Used (MRU list) in Floorplan Editor
- Additional response decodes possible in later UCM firmwares
- Other minor UI changes and bug fixes
