Dear all,
I\'m pleased to announce the release of version 3.1.1.51 of ComfortClient.
This builds on the previous release and makes the leap into the world of .NET4. You will need at least .NET 4 Client Profile installed to use this version. Dont worry though as Windows will install this for you if necessary.
This release is the culmination of 3 months of development, most nights after work, and I can\'t thank Ingo enough for being with me all of the way on this release. He\'s a real star and a credit to the Comfort Forum community.
In addition to a lot of bug fixes and smaller updates, the key features of this version include:
Specifically:
Version 3.1.1.51 ââ¬â (26 Aug 2011)
Architecture:
You can download from the updated link at:
http://www.comfortforums.com/forum65/1948.html
or at my website at:
http://www.futurehomesoftware.co.uk
I hope you enjoy.
I plan to release a maintenance release (smaller build) next, followed by a major release later in the year.
Enjoy.
Quote:[*]Linear Gauge floorplan objects
[*]Support all UCM connection types to PC; UCM/Ethxx, UCM/USB & UCM/232
[*]USB auto detection (plug-and-play)
[*]Feature refresh on all existing floorplan objects
[*]Improved UCM connection management, reliability & recovery
[*]Support features in new UCM & Comfort firmwares
[*]Better handling of alarm states
[*]General UI refresh
[*]Other minor new features
Specifically:
Architecture:
- Microsoft .NET 4 (Client Framework) console application developed under Visual Studio 2010
Quote: Tested against Comfort version:
- Comfort II Ultra: Firmware ââ¬â 6.005, File System ââ¬â 34
- UCM05: Firmware ââ¬â 6.008
Quote: Bug Fixes/Changes
- Improved object border resolution and colour accuracy.
- Connection settings are initially checked (as far as possible) for validity when the Connect button is pressed.
- Control menu tree on Home Control tab used to refresh status values every 60 seconds. Now it also refreshes immediately any of the status values change.
- Corrected minor digit version decodes for ââ¬ÅUââ¬Â and ââ¬Åuââ¬Â commands. The new UCM firmware for example decoded as 6.02 whereby it should be 6.002 as per Comfigurator.
- Last write date (Comfigurator to Comfort) and last update/write date of CCLX file now displayed on ââ¬ÅCCLXââ¬Â status bar icon tooltip.
- Key press on main ComfortClient Floorplan area when no window tabs are added cause an ââ¬Åindex outside of bounds of arrayââ¬Â error.
- The ââ¬ÅIsPercentageââ¬Â checkbox for Label Objects was incorrectly available for Modbus Object Types.
- An attempt to start a second instance of the ComfortClient now displays a cleaner error message.
- Connecting to a target device which was not a UCM could cause the ComfortClient to receive unexpected data resulting in a continual retry loop. The ComfortClient had to be closed to clear.
- Better error reporting when attempting to connect to an unknown target connection.
- Extra attributes added to Floorplan Editor Query report plus support for Linear Gauges.
- C to F and F to C conversions were not calculating correctly on Counter & Modbus Types.
- Modbus plugin queue processing did not stop when connections disconnected prematurely.
- Comfort references used in Floorplan and System Conditions were not correctly queried at logon.
- Logon Code field now only accepts numeric vales and maximum 6 characters.
- Incorrect window could be opened in FloorplanEditor if Window Tab names are the same.
- Inserting a new Floorplan object and cancelling out of the properties window did not clear the status bar selection counter in FloorplanEditor.
- Labels linked to counter responses did not correctly support visibility filter (condition).
- Circular Gauges now support a negative scale number colour property (aligned with Linear Gauges).
- Tab Icon tab clear logic has been improved.
- Activity Tab Reset Time did not have any effect but has now been implemented.
- Visibility filter on Modus Object Types are now supported. Sounds Tab for Modbus Object types is now disabled as functionality is not currently implemented.
- Gauge background images were not tested for validity when loading Floorplans; ie that the image file is located in the images folder. Missing image placeholders are identified by a red border and cross.
- Improved handling of duress conditions; the discrete ââ¬ÅDuress LEDââ¬Â and ââ¬ÅSee LEDââ¬Â alarm state message now replace messages that contain ââ¬Åduressââ¬Â so as to not alert intruders to this condition.
- For Network connections, Auto-Connect incorrectly tried to use the last IP address & Port set in ComfortClient rather than the value from the CCLX file, even though the override was not checked.
- CCLX status in status bar did not correctly support the PersistConfigurationMenus option.
- Other small UI clean-ups.
Quote: New Features
- Linear Gauges are now introduced.
- Selection and Copy to Clipboard now available on the Monitor, Monitor Snapshot and Event Log windows. Selection options include conventional Click, Ctrl-Click and Shift-Click combinations to mark one or more items and also ââ¬Åtype-basedââ¬Â quick selections (Copy All System, Outbound and Inbound respectively) and any combination thereof.
- Pause button now added to monitor window.
- Added links to ComfortClient forum and License Agreement from Main Menu (Information Menu).
- Circular Gauges now support Caption Text rotation
- GaugePacks now support Caption Text rotation
- UCM/USB connectivity is now supported, including pass-through via KT03.
- UCM/RS232 connectivity is now supported.
- IR Reports are now decoded.
- Attempts to Logon on an established connection which does not have a UCM at the other end now display ââ¬ÅNo Response from UCMââ¬Â when a logon attempt is tried.
- License Agreement is now accessible via the Help Menu as is a link to Comfort Forums, ComfortClient section.
- RS response (new in UCM firmware 6.005) now decoded.
- Event Log window now shows decoded entries colour coded (similar to Monitor Log window).
- Event Log can now be saved in OpenXML (docx) and RTF format as well as plain text.
- On attempting to connect to the UCM the ComfortClient now checks the Tibbo module on Eth01/02 daughterboard for any existing connections and warns the user accordingly (Network Connections only).
- Added Most Recently Used (MRU) list to FloorplanEditor File menu.
- Custom and system (windows) colours are now supported on Floorplan Objects.
- Last Alarm State is now shown as a dropdown list (newest first) on the Connection and can be reset via a ââ¬ÅClearââ¬Â button.
- Linear and Circular Gauges now support visibility and sound filters (conditions).
Quote: Known Limitations
- Animated GIFââ¬â¢s are not currently supported in the 2.1.2.x stream.
- Circular gauge needle primary colour (colour 1) does not yet support custom colours.
I hope you enjoy.
Enjoy.
