The new version of Comfigurator 3.3.3 has been releasef and is available for download from https://www.cytech.biz/comfigurator.html
It is highly recomemended to upgrade to this new version because of its imporved features and stability.
The changes (from 3.3.1, including the change in 3.3.2) are:
New Features and Improvements
- All checkboxes have to be selected by clicking on the box, and not on anywhere in the row containing the checkbox. This prevents unwanted checking of boxes, for example in Options > Settings > UCM Connections - when USB is selected, the \"Via KT03\" Box was easily checked by mistake as it is below the USB serial number box. This caused the USB connection not to work
- New Version of Tools > IR Learner Tool which has a checkbox when adding a new Code \"UCM B1045 and above\" Leave this checkbox checked when the UCM PCB datecode is B1045 and above
- When LU00 is sent by Comfort, Comfigurator will not disconnect from an Ethernet or USB connection, so when you try to log in again it will connect and login correctly and not give error message \"No Response from UCM\" because Comfigurator did not re-connect to the UCM
- RS report from Comfort logs out Comfigurator from the UCM
- Allow maximum of 96 zones in Ultra for future implementation.
- New Zwave configuration default file
- Read from Comfort autogenerates Response Descriptions and Names, see http://www.comfortforums.com/forum92/2470.html This was introduced in 3.3.1 but we would like to emphase the usefulness of this feature again
- Rs232 connection was not be able to connect if \"Via USB\" was checked in USB connection, then changed to RS232 connection
- Read Zones from Comfort could change the setting of Virtual Inputs incorrectly.
- If the Sound Type Name was changed, the Siren Type which points to the sound type was not updated
- CMS Account code did not allow hexadecimal digits B to F
- CMS Acccount code missed leading zero, eg 0123 is written as 123.
- Error Message \"Number of modules do not match the number in Modules and settings\" when opening a cclx file where UCM ID #1 is not present
- Fixed exception when scanning UCMs for Bus Upgrade where u? is not supported because of UCM firmware too old.
- Improved validation of applicable modules for Bus upgrade and Direct connection upgrade
- new defaults for Comfort I Templates which do not have 8 UCMs in Modules Tab
- In the KT03 Configurator, when zones were selected, then the zone name or properties are changed in Security > Zones, the KT03 affected zone does not track the changes. eg zone 2 is called zone 2 but if you change zone 2 name to something else, in KT03, the zone 2 name and text is not changed
- Fixed bug in 3.3.2 - Selecting KNX to Comfort or Zwave to Comfort tabs caused an exception
- When a UCM ID is changed, Actions sending messages to the UCM will still address the old ID. This affects \"external\" UCMs like Cbus, Velbus, KNX, Universal etc. This is an old issue and has existed since the beginning.
- IR Learner when the Start button is pressed and no signal is received for 20 seconds, will cause an exception
- After changing UCM Connection from USB to Ethernet, an attempt to login occasionally may cause an exception.
- In the Modules Tab if there are UCMs at ID 2 and 3 but not at 1, then if you ADD a UCM manually, the UCM is added at ID 1. Changing to ID 4 does not work. The name assigned to the UCM may be a duplicate of an existing ID.
- Scanning for modules especially over the internet (UCM/Ethernet) may give a message that the module does not support the SCAN function although it does. Repeat the scanning operation and do not change focus from Comfigurator.
