ComfortClient
This thread is for the 3.1.2.x maintenance release I\'m working on now.
Currently this includes:
* Bug fixes & tweaks; you can never have too many fixes!
* Windows autoscan
* Jump to Window based on condition
* ...other stuff I\'m working on which I\'ll post nearer to release date.
Drop me a PM if you are interested in me adding anything else.
Also, the next release will be the first where the installer, application and my developed DLL\'s will all be Microsoft authenticode digitally signed. This will ensure that any code cannot be modified once I have signed it, so its protection for you and also me too. Given it\'s a security focussed application then I want to be 100% sure that my code is safe from hacks etc.
It\'ll look like below when you install or check exe or dlls that makeup the ComfortClient.
OK so for those that are interested I shall shortly be releasing the next version.
Changes are:
Quote:Changes/Fixes
• Improved highlight selection on Monitor & Event Log list boxes; highlighted test is now white on blue for better clarity.
• Filters applied to SystemSounds could error on ComfortClient load for Zone, Output and Flag types used in condition criteria; i.e. where the result value chosen was On/Off or True/False.
• Selection handles are now shown correctly when selecting an object that is partially obscured behind another (foreground) object.
• A selected object which is completely hidden behind a foreground object can now be dragged.
• Maximum Zone (Z?) and Outputs (Y?) are now increased to 96.
• Maximum RIO Inputs (z?) and Outputs (y?) are now increased to 120.
• Improved decode logic for the compressed responses via threading; for f?, y?, z?, Y? and Z?.
• In Floorplan Editor the Set CCLX menu action (File menu) is moved to the Settings sub menu.
• Added Event Log decode for unknown Event types.
• Fixed exception when FLFFnn response is received.
• Increased Flags to 256 to support future Comfort firmwares.
• In System Sound Manager {Value} property was not available when changing sound phrase.
• Beep sound is now replaced by Windows System Sound equivalents (Beep, Exclamation etc).
• Connection Tab details were missing/corrupted in the Help file.
• Changing the border to none on a Floorplan Picture Object did not correctly refresh the image until the floorplan was saved and reopened.
• Snap to grid did not work.
• Sound On/Off menu action did not correctly check for sound files present.
• Improved handling of wrong/invalid user code entered.
• Further internal code refactoring.
New Features
• Tooltip and background colours now added to “Last Alarm State” dropdown on the Connection Tab in ComfortClient.
• Configurable windows scan on mouse/keyboard inactivity in ComfortClient.
• Can now set a “Home Page” Window Tab in Window Manager which is selected when the ComfortClient starts up.
• Jump to “Home Page” Window Tab on mouse/keyboard inactivity in ComfortClient.
• Jump to Window Tab based on the result of a condition.
• ComfortClient Installer, main executable and associated assemblies (DLLs) are now Microsoft Authenticode signed to improve code security and authenticity.
• A maximum age option can now be set to delete log files automatically as they age out. Applies to both ComfortClient and FloorplanEditor log files.
• Query All Flags (f?0x) is implemented.
• Added new Options menu action to Floorplan Editor FileSettings menu.
• In Floorplan Editor, ClickResponses now include an Infrared Template.
