Night mode
Just a quick one, How do I get comfort to only use the living room as an entry path when its set in night mode. When comfort is set to away mode I want an instant intruder alarm in the living room.
Thanks,
Chris.
Dont select the living room as an entry zone.
Instead call a Response EntryDelayNight when the PIR goes on to give you time to go through the zone.
Response EntryDelayNight would be
If SecurityMode = NightMode Then
Start EntryDelay
End If
Obviously if you already call a Response from the PIR On just slot that code in the existing response.
