This applies to the new UCM/ETH02 Ethernet module shown below
UCM/ETH02 replaces the UCM/Ethernet (UCM/ETH01) with the orange EM100 module
The main features of the UCM/ETH02 are
The older ETH01 looks like the image below
The UCM/Ethernet has better features that are recommended especially for the iPhone application, for example, if the ethernet connection is lost, the module will automatically log off Comfort
The latest UCM Manual which included the UCM/ETH02 can be downloaded from https://www.cytech.biz/ucm_manual.html
- 10/100 Base T Ethernet Port, more compact
- Ethernet module is programmable - this means the Ethernet interface itself is programmable with built-in Flash Memory and has its own firmware and application. This is not the same as the UCM Firmware which controls the communications between the Ethernet and Comfort. The Ethernet module firmware is uploaded using the DS Explorer
- Network Protocols: TCP, UDP, ARP
