01-23-2012, 11:19 AM
It is nice to have the responses that I create grouped together in the list of responses so that they are easy to find. This can be done by fixing them, say starting at number 300, but fixing has disadvantages.
If you start the description of your own responses with a particular string (your initials perhaps or \"AA\" or \"00\" or anything you fancy) then when using the \"Select a response\" window, you can click on \"Description\" to sort the entries by the Description field and all your responses will be grouped together (and at the top of the list if you choose your string carefully).
Even for the built-in responses, I think they are easier to find by Name or Description than by number and Comfigurator usefully remembers the sort order next time you open the \"Select a response\" window.
