Comfigurator 3.4.4
Comfigurator 3.4.4 shall be available for download soon. This mainly fixes bugs in 3.4.3.
The changes are
Bugs Fixed
  1. KT03 Configurator - if sensor status is used in Buttons and sensor name is changed, the sensor name remained unchanged in the KT03 page
  2. If Scan for Modules operation fails while attempting to do Firmeware Upgrade by Bus, Comfigurator is logged out but the Firmware upgrade starts without logging in again so it fails without getting started.
  3. Bus Monitor (in Tools) display is limited to 128 characters, and will result in the initial characters not displayed if the message line is longer than 128
  4. Number of Outputs for a 96 zone system remained at 64
  5. [color=\"#000000\"]UCM/Cbus may lose commands to group addresses if UCM ID 1 is NOT present in the Comfigurator and file is saved. This may happen if anither UCM or a KT03 is used to program Comfort. Workaround is to manually ADD UCM at ID=1[/color]
  6. [color=\"#ff0000\"][color=\"#000000\"]Zwave Comfigurator - Zwave Mapping unable to select Counter 000[/color][/color]
  7. [color=\"#ff0000\"][color=\"#000000\"]KNX Comfigurator Physical address is limited to 200, because of compatibility with UCM/KNX firmware up to 6.015 which is unable to work with physical addresses higher than 200.[/color][/color]
  8. [color=\"#ff0000\"][color=\"#000000\"]Event Log did not cater for Engineer Code changed from user 18 to 254
    [/color][/color]
Vocabulary File
  1. Myma36 bin file is included in the Vocab subfolder
Bus Monitor
  1. Can display more than 128 characters
  2. Display time stamp up to 0.001 seconds (millisecond checkbox added)
Known Issues (not confined to 3.4.4)
  1. Response Numbers could exceed 1023
  2. Responses with Errors (in Red) did not have any warning when the file is saved.
  3. Importing certain scenarios cause Comfigurator to crash
  4. Importing of Responses in certain scenarios was incomplete
  5. After a successful firmware upgrade the message \"Length Cannot be less than zero\" may be seen. This can be ignored
  6. \"Show Status\"  for RIO updates status when the box is checked but it  does not keep track of any changes in the RIO state
Comfigurator 3.4.4 beta can now be downloaded from https://www.cytech.biz/comfigurator.html
Comfigurator 3.4.4 is now a released version
