Comfort II Simulator
An updated Comfort II Simulator is available for download. If adds a few new features and some minor bug fixes. See below for information.
[size=2]
Quote:[size=2][size=2]Support the Time Program (TP) feature. Time Programs are read from the CCLX file and can be changed using the TP command.
[/size][size=2]Support for Reminder (RM) commands. This feature is not implemented in Comfort yet but I decided I’ll give it a bash to see if I can do it.
[/size][size=2]Supports the Extended RA and Sensor feedback. To enable, set the UCM/General Firmware version to 6.020 or above. Default is 6.001.
[/size][size=2]Local User Database can now be edited in the Simulator. You can Enable/Disable and change user passwords for users 1 to 16. CCLX integration is also done, if you load a CCLX file then the Username field and capabilities updates to whatever you have configured.
[/size][size=2]Action Code 152 (DA98) is now supported for Comfort firmware 6.019 onwards.
[/size][size=2]Log Replay ‘Loop Continuous’ have now been activated.[/size]
[/size]
[/size]
[size=2]The latest Simulator can be downloaded from http://www.futurehomesoftware.co.uk.[/size]
[size=2]Enjoy,[/size]
[size=2]Ingo
[/size]
PS. Attached is a modified sample floorplan for ComfortClient. This one uses Cbus actions to Switch the lights On|Off. To use it with the Simulator just load this new floorplan in ComfortClient and enable the UCM/Cbus in the Simulator. Just remember to rename the file extension to XML.
.txt   Cbus Sample 1.txt (Size: 16.93 KB / Downloads: 11)
