Infrared learner problems (UCM/ETH02)
Greetings,
i am having problems with the Comfort Infrared learner running on the
Comfigurator software (v3.3.3.0). So far i have tried these remote controls
1.) DAIKIN:        ARC452A3         (Air conditioner)
2.) SAMSUNG:    AA59-00466A    (TV)
3.) Unknown remote:                 (Projector)
I have tried every button on those remote controls, but the Infrared
learner was not able to learn and save any of the IR codes i have sent
to its receiver on the UCM/ETH02 module. Every time i get the same
error message (see attachment).
When i start the IR learning process, the BUSY1 LED turn on. Then after pressing
a button on the remote control, the BUSY2 LED blinks, followed by the D12 LED
and the ERR LED.
Am i doing something wrong? What is the solution?
Please upgrade to the latest Comfigurator software 3.4.4 Download from https://www.cytech.biz/comfigurator.html?category_id=98
See revision history on the forum at http://www.comfortforums.com/forum20/2738.html
You should always use the latest version so that bugs that were reported are fixed and we are all on the same platform
Thanks. Sorry, we missed this one. We\'ll try and report back if it hepls! Cool
No... Sorry, but it doesn\'t help. The problem stays the same, always the same error message. I don\'t know if it matters, but the UCM/Eth2 boards bear these markings:
UCM board: PC01-066A
Ethernet board: PC01-090A
We have verified that the UCM/ETH02 may have this problem when learning long IR Signals due to a limitation in the size of the ETH02 buffer. Our engineers are studying the problem
Are you using the UCM/ETH02 for the iPhone app? If not we can send a different firmware which may not have this problem but it not suitable for the iPhone app temporarily
No, we don\'t use iPhone app. Please send the other firmware. Is this firmware to be flashed by DS manager APP, or by Comfigurator?
Use Device Expplorer download from https://www.cytech.biz/device_explorer.h...gory_id=98
The firmware file is attached
Let us know if the IR learner works with the firmware
.zip   soi_application-3_11-(EM500EV).zip (Size: 303.99 KB / Downloads: 3)
Greetings,
i am using Tibbo Device Explorer (see attachment) to upload the new firmware. After selecting the programmable TiOS Device, pressing the UPLOAD button, selecting the
\"Load Firmware Through the Network\" option and browsing the new firmware file a
warning window pops out (see attachment) indicating that the chosen firmware might not be compatible with the selected device. I did not proceed with the firmware upload.
Is it safe to do this firware upload? Is there another firmware version that is
compatible with this UCM/ETH02 module?
Hi,agenor, sure,it is safe to do this firmware upload! if download wrong firmware, any time,you can press and hold the prog button on top of small PCB to initialize the module to its original state and upgrade again
OK, thanks! We\'ll let you know if it helped (regarding the original problem).
