07-07-2012, 09:24 PM
All,
It seems that the new Comfigurator 3.5.x now stores the configuration settings with different keywords in the CCLX file which is not backwards compatible with previous CCLX file versions so ComfortClient cant read.
If your CCLX file is in 3.5.x mode then for the moment please use the override checkboxes in ComfortClient Connections tab to instead store your connection settings in ComfortClient config. I guess I\'ll need to create a maintenance release to now work around!
Sorry about that but outside of my control, but looking at the revised keywords they\'ve used it would seem IMHO an unecessarily change that then affects downstream apps.
ie
\"UcmInterface\" => \"UcmConnection\"
\"UcmNetworkPort\" => \"UcmNetworkPortNumber\"
ie
