Threads: 63
Hi ident
Have installed the most recent version and still seem to be having probd
When trying to log in I keep getti.g connection tmeouts! Also I Di.d when I do manage to log in it still takes a very long time to get status of devices etc!
Eamon
Threads: 63
Hi ident, just to give an example, it took over 60 secs to get scs temp readings to display on my android app just now. This was connecting locally by wifi.
Regards,
Eamon
Threads: 476
Thanks for the feedback, we are still working on improvements to the android apps
Threads: 19
HI I have downloaded a copy of this to try on my phone, I can get it to connect and to open, but I cannot get the file to load the configuration, I have it emailed to my phone and click view on Gmail as that is the only option it gives, It them lets me select the option in the App but does not load the details into the app.
I am using Gmail, Samsung Galaxy S2 with Android 4.0.4. Should this work fine? I know from earlier versions that the newer androids where not supported but I thought they where now.
Threads: 476
The important thing is to read the email using an email (gmail in your case) client and not by webmail. Using webmail you will not be able to load the attachment
Threads: 19
HI Thanks,I am using Gmail and not Webmail, the options in Gmail are View or Save, I click View and it asks me to select the App setting to use. I select my Comfort setting and then it confirms that it was selected, the email then stays in the foreground and nothing else happens.
Threads: 19
Just an update, I tried it with the android email client using a different email address and it has worked, it may be an issue with how GMAIL reads the file. it dosn\'t confirm that it has loaded the file but I selected the file and the location, then went to the Comfort app, logged in and it was working
Threads: 19
Hi I am away for a couple of days and will check when i get back. I Know I was able to see some home controls after a few attempts at loading the file so it must have loaded. I guess that as you progress thr app then it will be easier to load. Would be great to have a import functiion in the app or feedback as to progress and when it has loaded
