For those interested, we\'re just debugging a new version of ComfortClient which currently has the following changes and new features.
Hopefully it\'ll release soon.
Quote:Bug Fixes/Changes
ââ¬Â¢ Scroll bars now correctly appear in FloorplanEditor when the editor panel is smaller than the size of the floorplan.
ââ¬Â¢ Value Transforms were incorrectly enabled for SENSORS when object type is Circular or Linear Gauge.
ââ¬Â¢ Value Transforms did not work correctly for COUNTERS for object types Label, Circular and Linear Gauges.
ââ¬Â¢ In FloorplanEditor, tabs for unrelated object properties are now suppressed. For example when editing a LABEL object, tabs for PICTURE and GAUGE are now hidden.
ââ¬Â¢ Holding down SHIFT key whilst dragging selected objects in FloorplanEditor, either by key or mouse dragging, will show just the outline. For improved performance on low spec systems.
ââ¬Â¢ Improved support for BPXX command.
ââ¬Â¢ UI minor font corrections (ââ¬ÅSegoe UIââ¬Â is standard).
ââ¬Â¢ Flag Names were not written to the log file.
ââ¬Â¢ Two log entries were written (incorrectly) to the log file for each bitwise command received; for Y?, y?, Z?, z? & f?.
ââ¬Â¢ Shorten time for Splashscreen to show at startup for ComfortClient and FloorplanEditor.
ââ¬Â¢ Improved startup. ComfortClient & FloorplanEditor are now NGENââ¬â¢d on startup to pre-compile the application for faster startup.
ââ¬Â¢ A Drag & Drop exception would occur if you attempt to open FloorplanEditor when no Floorplan Tabs are added in ComfortClient and the OK button is selected in the pop-up message that suggests redirection into WindowManager.
ââ¬Â¢ System Sounds is now moved to a new playback thread to improve performance.
New Features
ââ¬Â¢ Holding CTRL key down during ComfortClient application launch disables plugin load. The ââ¬Å-Xââ¬Â command line switch also does the same.
ââ¬Â¢ Holding SHIFT key down during ComfortClient application launch disables AutoConnect (if otherwise normally set to auto connect). The ââ¬Å-Aââ¬Â command line switch also does the same.
ââ¬Â¢ Start-up time now displayed in monitor and log files.
ââ¬Â¢ New right-click menu on floorplan tab:
o Clear Tab Log
ââ¬Â¢ Entry/Exit delay countdown is now shown on the status bar. Note: this is for guidance only and accuracy will depend on how quickly the trigger message (countdown start) is passed to ComfortClient over the UCM connection.
ââ¬Â¢ Progress bar added to FloorplanEditor splashscreen. The ââ¬Å-Pââ¬Â command line startup switch added to suppress the progress bar on startup if required.
ââ¬Â¢ System Info window now can be resized vertically. The maximum size depends on the number of modules discovered.
ââ¬Â¢ System Info data can now be saved to a text file.
ââ¬Â¢ Added new Search Object feature in FloorplanEditor.
ââ¬Â¢ Rounded Borders are now available on all object types for ââ¬ÅFixed Singleââ¬Â and ââ¬ÅCustomââ¬Â border types. Note: You can use this feature with appropriately sized rounding values to create circle objects too!
